Posted by Gary Mullens on 07/10/2017 01:39:19:
Are their any build threads with car heater motors? I have been reading articles on action electronics trying to educate myself on the setup. Now, I understand a single speed 2 wire motor will do but what about the 2 speed motor setup? Anyone care to share how the setup will work? The components etc? There has to be more info or threads on this. Right?
Now for my next question. What source is their for the 4 and 5 inch propellers?
To control your motor, you will probably want to use easily available parts to go between radio and motor. Effectively, this means an ESC intended for model use, which is expecting a 2 wire motor. If the motor is a straight DC type, but with the odd extra wire for cheap speed control, it would be best to ignore the "extra" wire and just use the two that give "normal" performance, allowing the ESC to do its job.
At one time, it was possible to browse a scrapyard and select the goodies you wanted – nowadays, you need to know the make and model and year, if not the actual registration of the car you intend it for. Using a motor for any other purpose is a foreign concept, for the sellers, things like "technical specifications" are equally foreign. The only common point is that they are designed to work on a nominal 12 volt system. Unless it fell off a truck. Quite often a nice new "proper" model motor is a lower cost option with a high probability of getting a setup that works.
Raboesch list props up to 130mm, spotted on http://www.cornwallmodelboats.co.uk/acatalog/R147-M5.html Those are BIG props, and will need a big diameter motor (rule of thumb, motor diameter will be greater than prop diameter) or gearing. a toothed belt and pulley system would probably be the best option.
