Advice on motor and shaft please
Home Forums Beginners Advice on motor and shaft please
  • #33278
    wayne quigley
      @waynequigley28540
      afternoon guy
      can ay one suggest a motor and propsharft combo for the following hull
      I have a link to a hull similar here
      950mm long
      150mm wide
      130mm high but 1 would like to have 40mm above the water line
      I am not looking for a mega fast shipp but would like it to be able to get out of any trouble quick
      also are water proof shaft worth the extra or is it worth puting a collection vessel ate the enternal end to collect ant leakage and empty regulary
      cheer
      Wayne
      wayne quigley
        @waynequigley28540
        #33281
        wayne quigley
          @waynequigley28540
          the comment about propshaft should say collection vessel at the end of propshaft at the internal end for water collection
          cheers
          Wayne
          #33282
            Wayne. Difficult one this, everyone will have their own preferances.
            To start with, what battery do you think you will be using ?? I would have thought a large gel cell, say a 12v 7A hr one or something would do..you will need a bit of ballast anyway. An MFA 800 turning a 50mm Prop on a 5mm shaft would be an option, or a geared 850 for more oomph…or come to that just an 850.
            There are several 900 types out there to direct drive a large prop..or geared 700`s.
            I am afraid a surf will be needed, perhaps Cornwall model boats…they have a good range of motors and geared units.
            The hull looks a bit yacht like? from the bottom view.
            Personally wouldnt bother with a waterproof shaft. Wont have much leakage and in a fibreglass hull of that size it wont matter anyway.
            Edited By ashley needham on 05/02/2012 10:42:39
            #33286
            wayne quigley
              @waynequigley28540
              thanks for your input I had been looking at a 545 motor so glad i asked
