68 foot RTTL Vic Smeed plan 530
Home › Forums › All things floating › 68 foot RTTL Vic Smeed plan 530
  • #121082
    Mark Randall 1
      @markrandall1
      Hi,
      I am building the Vic Smeed Vosper RTTL plan 530, but I am building it 50% lager than the plan.
      This represents an overall length of approximately 49 inches, with a beam of approximately 14 inches.
      The plan recommends twin Taycol Meteors motors (which I have!), can anyone suggest suitable modern brushless motors, bearing in mind the 50% in size.
      Many thanks for any suggestions.
      Mark
      #125284
      Terence Gregory
        @terencegregory
        Hello Mark, just joined the group after some time away. I assume you may have finished the RTTL? I was just going to add I built one a couple of years ago which ended up to be 68 inches long with 2 large brushless motors(totally over powered). If you would like to now more please reply. I do not know how this forum will notify me of anything being added.
        Terry
        #125285
        Terence Gregory
          @terencegregory
          Hi, I didnt see the tick box at the bottom, hence this strange reply.
          Terry
          #125291
            Hi Mark
            What size are the props so we can give you an answer??
            I think they are 3 blade props for a start.
            Note brushless motors are far more powerful than the brush motors.
            Harry
            #125293
            Terence Gregory
              @terencegregory
              Hi, I used two turnigy Aquar start which can be wired in star or delta. the problem came from the esc which would need to be 200amp to cope with delta. I left them in star and with 150amp esc and putting a 40mm prop reduced the current load to one which worked very well. I even had to reduce the control throw on the tx to 75%. If you want to see this, there is a video on Oxfordmodelboatclub website.
              Terry
