Viewing 25 posts - 1 through 25 (of 85 total)
  • #11325
    Ducky
      @ducky
      This is one of those RNLI shop bought boats,Its had the electric’s replaced and its a nice second boat for my wife and its great for letting visitors have a go,for as you know once you’ve had a go you’re HOOKED!
      Superstructure now comes off to put in 7.2. 3000mah battery and it goes quite well
      Chris Pearce
        @chrispearce30862
        Hello,
        I just bought one of those RNLI boats for the kids, seems a bit ..! and pulls to the left eerr port, being a complete novice (not 1 star yet) what could I do to give it some ummph.
        A. better engines, what sort?
        B. new electrics, again what type?
        C. anything else?
          Cheers ChrisP
        #15333
        Ducky
          @ducky
          Hi Chris
          Sorry I can’t help you there,I bought my lifeboat already converted and all I can say is that its had the two motors taken out and one central one replaced,and a small esc and 27meg receiver fitted.It still goes quite fast with a 7.2 battery fitted and I’ve refitted the deck and filled all the holes in same as it was more like a colinder when we bought it.
          Sorry could’nt be of more help.
          Ducky
          #15335
            There has been an MB artcle on this subject  hasnt there ??? cant remember which  issue     Ashley
            #15336
            Ducky
              @ducky
               You’re right Ashley ,perhaps Vinnie can point it out
              Ducky
              #15337
              Vinnie Branigan
                @vinniebranigan92297
                Not a chance. Wouldn’t know where to begin.   It’s not like I have an index or anything.
                Vinnie
                #15338
                Ducky
                  @ducky
                   You do surprise me Vinnie,and I thought you were the fountain of all knowledge.
                  Perhaps some of the others members could put Chris on to it.
                  Ducky.
                  #15339
                    The best thing that Chris can do……..is join a model boat club…………He`ll get all the help he needs!
                    Len Ochiltree
                      @lenochiltree67043
                      I seem to remember that Alan Poole did an article about converting the above boat.
                      Are you there Alan??.
                      Len.
                      #15352
                      raymond broadfield
                        @raymondbroadfield80452
                        a very good article on how to upgrade this lifeboat was written by a Dave Wilson in a Model Boats kit special winter 2006
                        #15353
                        Alan Poole
                          @alanpoole81825
                          Hi all,
                          Yes I did convert the RNLI Severn class lifeboat when it was first released and did an article about it for MMI. It is the Feb 2007 issue.  The first advertisement for this model appeared in the Lifeboat Journal and I subsequently found out that the RNLI had been 2 years in developing the model with the manufactures in China. It is an accurate little model and well worth converting to a better control system. Weight is very important , and using the lightest possible equipment will pay dividends, mine is a great little regatta boat.       Always happy to help.
                          Cheers  Alan
                          #15356
                          Chris Pearce
                            @chrispearce30862
                            Hi to one and all,
                            Thank you for the help and advice, Alan, since I’m a novice, what does MMI stand for and all the conversion is in this copy?
                             I will set about and track one down.
                             cheers
                            ChrisP
                            #15357
                            Alan Poole
                              @alanpoole81825
                              Hello Chris,
                              MMI stands for Marine Modelling International Magazine, it is another  model boat publication by Traplet publications.
                              The conversion is an easy task on this model, I believe I covered most aspects of it in the article with several photos which should answer and clarify most questions.
                              Also as mentioned above, Dave Wilson did do a similar conversion article which appeared in the Model Boats Kit Special publication Winter 2006. The approach was slightly different but the basic ideas are  the same. You should still be able to get copies of the above magazines from the publishers, Traplet for MMI and Encanta media for the Model Boats Kit Special.
                              Regards  Alan..
                              #15360
                              60watt
                                @60watt
                                I sailed a friend’s scratch 12th Arun…….The most fun I had sailing a surface craft.
                                Downside is the owner gets asked the same question from all general public who spot it from 100 yards!  WCIGO
                                At 12th tthe Arun had a pair of direct coupled high torque 24 fan motors drawing 5 amp.
                                Car fan motors at this scale.
                                Tom E
                                #15376
                                Alan Poole
                                  @alanpoole81825
                                  Hi Tom E, or is it Tommy,
                                   Did you work at Bletchley Park ?
                                  Regards  Alan..
                                  #15377
                                  60watt
                                    @60watt
                                    We haven’t met.
                                    Now my nose is itching.
                                    I’d better get my Avatar up incase there are any more Tom’s with model boats.
                                    Edit : Uploaded my mug and it’s being vetted ..I hope my face is accepted.
                                    2nd edid: removed double entendre
                                    Tom
                                    #15437
                                    Chris Pearce
                                      @chrispearce30862
                                      WCIGO? I had my machine with big valves on but still no eyed deer
                                      I see some sites are now selling kits for the Arun and other life boats, now do I convert the plastic one or get a kit mmmm
                                      ChrisP
                                      #15440
                                      60watt
                                        @60watt
                                         Where …….
                                        #15441
                                        Alan Poole
                                          @alanpoole81825
                                          Hi Chris/ 60 watt.
                                            Check out the Model Slipway range, they do some very reasonably priced little models that with a bit of superdetailing make superb little models.  You could also build their Trent lifeboat that makes a very nice model that is a bit bigger.  You could  go the whole hog and get a kit from Speedline at the larger scale of 1/12th, superb detailed kits but more expensive, this is the  traditional model lifeboat scale. and lastly, Don’t forget dear old David Metcalf of Metcalf Models who also does a large range of very well respected model lifeboats.
                                          Cheers  Alan..
                                          #15445
                                            Alan, chaps. I suppose it boils down to personal preferance.  A converted RTR is certainly handy to stuff in the boot of the car and is fairly tough and resistant to damage. Obviously not as nice as pukka kit. Do both! The RNLI boat is certainly cheap enough. Ashley
                                            #15462
                                            Chris Pearce
                                              @chrispearce30862
                                              Alan/Ashley,
                                              I have just come into modelling, now i’m totally hooked, been pouring over the websites, I want everything, well… just a couple. I think I’m going down the path of converting the plastic seven so the kids can have one, then, when her ladyship thinks  I’m totally mad, get  myself a larger RNLI, why umm, I suppose they look great.
                                               The big kid has been released..
                                              #15464
                                              Ducky
                                                @ducky
                                                 Hi Chris
                                                When her ladyshp thinks your totally mad present her with a boat of her own and then when she is hooked you can get yourself anything you want.
                                                See my album for other boats my wife Velda and I have between us and she can sail all of them,but still not quite sure of yachts yet but getting there,I build ’em and she sails ’em,seems a good arrangement to me!.
                                                The plastic Carlson tug that is sold by Howes Models is just the thing for the kids and virtually unbreakable.
                                                Ducky
                                                #15480
                                                Len Ochiltree
                                                  @lenochiltree67043
                                                  WCIGO,
                                                  Maybe it stands for,  Where can I get one.
                                                  Do I win one as a prize ?
                                                  Len WYBMADIITY.
                                                  #15489
                                                  Alan Poole
                                                    @alanpoole81825
                                                    You’ve started something now !
                                                    Cheers  Alan.
                                                    #15490
                                                    Vinnie Branigan
                                                      FGSNA -ICRBBWTCA.
