Noel. Don't think that the hydroponic coating will make a lot of difference, as a percentage.
Increasing volts will of course increase thrust and not the wetted area…ALTHOUGH with the extra thrust more lift might be gained cutting the wetted area.
Not much you can do with the basic hull, a new one would be needed. Any 40A ESC will take 12v no probs. Check motor to see if THAT will, but if it is brushless then it most def will take the extra.
Trevor has asked to borrow a model of something that I have, a pylon racer/tethered plane (only its not a plane, as such) to take measurements and so on from. Good stuff…used in conjunction with the fins from the Dragonfly??
Tackled propulsion on second project, project S. All glued in and had a quick test in the bath to make sure none of the joints leaked. WOW!! looking forward to this one! Wheres the mop?
Access to the insides on S is good barring of course the bits you REALLY need access to, like the rudder. To save hassle later on I will have to finish off the rudder bits and fit the tiller and then stick the deck on. There is finger access, but it would be tight. The deck will be stuck on with the hull upside down. Although the top of the hull is straight, it MAY not be 100% straight, and if I put the deck on a flat surface and then stick the hull to the deck, it will be absolutely flat and any small gaps can be filled easily. It is level side-side so no worries there.
HAve to visit the marina tomorrow and buy some marine grade silicone sealant to stick something in the boat. The marine stuff is an entirely different animal to the bathroom variety, much more gluey and sets a bit harder.
