Have floated the project in the bath just to get a feel for the likely amount of ballast needed (about 7 kg worth) and to see if it leaks which of course it does…a pinhole either end, not much to shout about. Ballast distribution seems an easy split for/aft with a portion in the middle. The battery is so light in comparison I will decide much later where to put it. Had a quick surf, in mid-post and 1.6mm lead shot is currently about £5 a kilo. I have lead sheet but I like the shot idea, as , mixed with resin, it will not only be as low down as possible and fill in the nooks and crannies, but will actually strengthen the hull and provide a measure of its own support.
Started the NEXT project now, to run alongside the main one, as the first is going to take a long time.
It is a battleship, about half the size of the first one, and I have the necessary materials and mechanisms for construction to hand, ordered from the same supplier as the first project.This will be project S, the first one I have renamed project V as it is actually more appropriate.
This is what the light grey will be for. This project will be very straightforward indeed (for me, obviously it is an advanced cutting edge product that some would find daunting), with no masts or rigging to worry about and will have good interior access, learning by my recent experience and using cling film (don't tell the wife) to assist this. It is based on something or other, and there are pictures aplenty on the interweb to use as a guide. Have not found any line drawings or plans yet but this does not matter too much in this instance. As I say, cutting edge.
