I would see how you get on with the planking at the bow, and plank until the curve just gets too much (down forget you can make 1/2 cuts at the back of the strips to help the bending and THEN foam.
See. easy with the right equipment eh!! get some spare blades in . It doesn't take much to break them.
Mintanic coming on a treat, up to "planking" the rear hull curve now, and going better than expected.
Undecided on what motor to use. I have no 385s or 540/1s, only speed 400s and a 540 of unknown type. I do have a couple of 555s and Graupner ECO 600s….but the 555s are horribly sluggish on less than 12v esp as I will be using a small 35 ish mm prop, and the 600s are overkill. I expect the boat to be heavy-ish so a bit of oomph is required, so perhaps my 540 is best.
As designed the top roof will lift off complete with funnels (found some plastic 22mm plumbing pipe) and it can be turned upside down to lessen box height!
