Thames Sailing Barge Stuff
Viewing 25 posts - 276 through 300 (of 782 total)
  • #80749
      Hi Eddie
      She is very Norfolk Broads 'ish another type of cruising yacht on my to build list 😃
        Hi Eddie
        She is very nice and Norfolk Broads 'ish another type of cruising yacht on my to build list 😃
        Oops twice !!!
        Edited By Ray Wood 2 on 20/01/2019 19:19:12
        #80752
        tomarack
          @tomarack
          Hi all,
          my wife broke her left hand before Christmas, it is a long time for me, so I will not get to the workshop before next week (I have to do all the homework, including cooking and cleaning etc etc..). Next week maybe she'll have hand in order. Meanwhile, I devote myself to the theory of sailing and balancing the rigging at present.
          The situation looks like this: adding a bigger Jib I created a Capricorn model with a lee helm.but the model could be controlled without any problems-
          Maybe another solution would completely eliminate the big Jib. Centre of effort could be moved backwards, and the model should then sail with weather helm,( this possibility did not come to my mind.) but sail with lesser sail area.
          Experts recommend that ships with a weather helm are safer. But somewhere I read that perhaps a small lee helm at the barge is better. I'll have to try it all out. What experience do you have with the balance of the rig ??
          Greetings Tom
          #80762
          Eddie Lancaster
            @eddielancaster
            Hi. Tom, I'm sorry to hear of your wives accident, I hope she will soon be fully recovered.
            My experience of sailing barges is nil at the moment! and very limited with other sailing boats so at the moment I am not sure if any shortcomings in the boats performance is design or helmsman induced!
            I will talk to you later in the season when I have sailed Susie May a few times.
            Regards.
            Eddie.
            #80776
            tomarack
              @tomarack
              Hi all,
              as I wrote to Dave,
              my wife now has a hand in a gypsum dressing, it looks like her hand is fine. The doctor will take her dressing off this week. But he will need further rehabilitation. For me it means I will finally have time for my hobby.
              I tried to find some references to the rigging and hull ballance, I found several articles that contradict each other.
              John Leather (in his book "Barges" wrote : As in many barges, the centre of Area of sails was arranged to be forward of (centre) lateral resistance with the leeboard in use,which teoretical relationship usually resulted in good ballance under sail and an easy helm in most conditions".   –  in my opinion this is also true for models with a central fin
              According to this statement, my Capricorn should be then  suitably balanced.  It will be seen when I have the chance to let it out in the bigger wind.
              Anyway, I will try all the options for both my models.
              Greetings   Tom
              Edited By tomarack on 21/01/2019 17:16:14
              #80820
              Eddie Lancaster
                @eddielancaster
                Susie May
                Susie May on the water for the first time, the sun was shining it was 11 deg. and a nice breeze blowing, it was either go to the pond or wash the car!
                Susie May
                She sails both ways!
                Susie May
                I was very pleased with how she handled, very responsive to the rudder, I didn't try the leaboards I have left that for another day..
                Regards Eddie.
                Edited By Eddie Lancaster on 25/01/2019 16:50:56
                #80821
                  Looks good Eddie.
                  I went down the pub! Looking fairly mild tomorrow so will wash the car, it's absolutely filthy.
                    Hi Eddie
                    Well done she looks good, the secret of getting the stay sail to work is to have the line is attached half way across the cross trees 😊
                    tomarack
                      @tomarack
                      Hi Eddie,
                      she looks nice on the water. We had too 11 °C – but below zero .. everything is frozen,
                      Today I started to make brail winch,and I will gradually make crab winches , probably again vertical, and pulleys, including the double pulley for the mainsheet. it is a slow manual work,
                      Greetings Tom
                      #80826
                      Eddie Lancaster
                        @eddielancaster
                        Hi. All thanks, I was pleased with her.
                        Ray when I saw your Veronica at Headcorn I noticed that was where you had the sheet attached, I will change mine for Sunday after I;ve washed the car!
                        I am going to make all the winches for Cambria from brass and hope to make them work, as you say fiddly work.
                        Best wishes to you all.
                        Eddie.
                        #80828
                          Hi Eddie,
                          Busy work week 2 days in Boston Lincs on business got there in the dark and came home in the dark, car filthy 12" crack in windscreen , good week ! In the workshop now very happy ☺☺
                          Eddie Lancaster
                            @eddielancaster
                            Hi. Ray, interesting that you have been up to Boston, that is where my friend lives, the one that I have refurbished two pond yachts for.
                            It's good to have a workshop to retire into, although other problems don't go away you can forget about them for a while.
                            Don't know how but I have just found myself with a paint brush and a pot of paint in my hand painting the hall, it's the centre of the house and every room opens onto it, so a few days away from the boatyardsad.
                            I forgot to have a lay down in a dark room 'till the feeling passed!
                            BTW your fishing boat looks good, I like the colour sceme, it will look good on the sideboard in the living room, so no need for a motor.
                            Regards Eddie.
                            #80844
                            Eddie Lancaster
                              @eddielancaster
                              Sorry Colin I missed the h from scheme in my last post.
                              Eddie
                              #81007
                              Eddie Lancaster
                                @eddielancaster
                                Cambria frames
                                The final cardboard frames for Cambria have now been marked out onto 1/4" ply ready for cutting and final fitting to the keel before the notches for the gunwales and chines are cut, and the centres are cut away leaving just the frame. I have retained all of the water lines and the centre lines to help with setting up on the keel.
                                Cambria frames
                                I think I am now ready to start to finish the frames, after two pieces of 1/4" square have been added to the sides of the keel to glue the bottom skins to.
                                Regards.
                                Eddie.
                                #81008
                                  Hi Eddie,
                                  I always think cutting out the centres of the bulkheads is so tedious but using a Starrett hole cutter for the corners and a coping saw does the job 😀 just tracing the bulkheads for HMS Belfast 19 of them, need to find a 6' 6" building board.
                                  Now you have a barge to sail, you can enjoy building Cambria 😇
                                  Eddie Lancaster
                                    @eddielancaster
                                    Hi. Ray, are your boats getting bigger? I agree having one barge complete I can now take my time on Cambria and hopefully build it true to prototype.
                                    We had a wet day here yesterday, Fri. so I managed to cut all the frames using the scroll saw so can now fit them one at a time, allowing the glue to go off before fitting the next one, each frame can then be set true and there is no danger of knocking it when you try to fit the next one.
                                    That building board will be the size of a doorlaugh.
                                    Regards.
                                    Eddie.
                                    #81016
                                      @timrowe83142
                                      Eddie
                                      I think Ray is building up to building a boat big enough to escape on!
                                      Tim R
                                      #81020
                                        As Tim says once I'm afloat will start start digging the tunnel
                                        But living in paradise what's to escape from ??
                                        Regards Ray, with a cold one in my hand
                                        #81047
                                        Eddie Lancaster
                                          @eddielancaster
                                          Another wet day yesterday, so some more time spent on Cambria.
                                          Cambria frames
                                          Cambria frames
                                          Frames are now all fixed to the keel and ready to have the gunwales and chines fitted.
                                          Eddie.
                                          #81049
                                          nick viner
                                            @nickviner52422
                                            It is starting to look really good. Cambria was always a lovely big barge. I knew her from her voyages around the East Anglian coast when I was young and living in England. I had a wherry house boat at Pin Mill where Bob Roberts lived.
                                            Regards, Nick Viner.
                                            #81056
                                            tomarack
                                              @tomarack
                                              Hi Eddie..nice work!!
                                              I added several folders with tsb Kathleen to Dropbox
                                              greetings
                                              Tom
                                              Edited By tomarack on 11/02/2019 18:08:47
                                              #81057
                                              Eddie Lancaster
                                                @eddielancaster
                                                Hi. Nick, it's nice to be building something that people remember seeing in her working days, I think Bob Roberts made her special by keeping her going for so long as a trading vessel, and just under sail with no engine.
                                                As you say she is big, I hope I will be able to cope with her when she is finished.
                                                Hi. Tom nice to hear from you again, I will have a look in drop box.
                                                Regards to you both.
                                                Eddie.
                                                #81066
                                                  Hi Eddie,
                                                  Thanks for your kind comments on sfb thread , is the Cambria drawing one of Richard Chesney's ? He was working on a drawing for Tiny Mite a barge yacht, when you see it you will want to build one 😀
                                                  tomarack
                                                    @tomarack
                                                    In recent days, I have finished the production of pulleys for Gusty Cat.
                                                    The tips of my forefingers are totally abraded . Link > https://tomarack.rajce.idnes.cz/Gusty_Cat/#IMG_1560.jpg
                                                    Tom
                                                    P.S. Ray please ..write me your  e.mail address
                                                     I want to write to you, but I got a message >You message could not be delivered. -Permanent Failure – Other or Undefined Status )
                                                    Edited By tomarack on 12/02/2019 21:54:15
                                                    Edited By tomarack on 12/02/2019 22:00:16
                                                    #81068
                                                      Hi Tom
                                                      I have changed my job again, will PM my new email address to you 😀
                                                      Regards from the uk
                                                      Ray
