nimh battery capacity
Home Forums Beginners nimh battery capacity
  • #46638
    charlie berry
      @charlieberry84446
      I see a lot of batteries rate at 1700 what does this mean ?
      I have a brushed motor that draws 1.75amps how long would this motor run wiyh this battery
      charlie berry
        @charlieberry84446
        #46640
        shipwright
          @shipwright
          Hello Charlie,
          Have a look at :
          #46643
            1700 refers to the amount of energy that the battery stores. Think of it as the number of gallons in a fuel tank. It is 1700mAH, or milliAmpHours or 1.7AmpHours. It means that you can, give or take a bit, pull 1.7 Amps for one hour.
            When you start drawing higher currents, you need to consider whether the battery is designed to deliver the higher current. In general, if your battery looks like it is made of "C" sixe cells, no problem. If it looks like it was made of "AA" or smaller cells, there might be some extra thinking needed.
