hello again, thankyou for the welcome
. I'm sorry Paul, no more photos at the moment, the model lives on the boat, but I shall be down there at the weekend, so will take some then. The under body is pretty much what you would expect, long straight keel, shallow draft, flat floors and a quick turn at the bildge.
You maybe quite right about the toy car radio, Bob, but as I use her when we are out on the big boat, there are no freqency hash ups, and the dinghy is always handy! The range is better than I expected, she gets hard to see before I lose contact. Here are some photos of where I'm up to on the paddleboat.
The hull is very simmilar to a cornish pilot gig, it would be hard to find a hull more easily driven! 37" x 5". The electrics are from a german made 'educational toy' , Fisher technic. The specs are: solar panel 3v 240mh, capacitor: 2.3v 10f , motor 3v with a 20ma idle current, built in reduction, with a massive 50 rpm shaft speed, but loads of torque. So paddle wheel was the only option (other than oars!) The motor runs for ten minutes on the capcitor alone! So all very effcient , but flea power non the less.
Couple of questions, if I may. Given a very slippery 37" hull, and a 5 1/2" diameter paddle wheel, what sort of paddle wheel rpm should I be aimming for? How deep should the wheel be immersed? and finally what sort of blade area?
thanks once again
Amy jane
