Hi Dan,
If your ammeter is a multimeter you can monitor if your chargers are actually charging or just floating as good chargers do.
The charge voltage when you put used batteries on is about 14 ++ volts (but may not reach that level for ages if your battery is really spent ). A two step charger will drop the voltage to a safe backup voltage of 13.5 volts at the end of the charge cycle.
Check for a regulated charging current of 400mA because that will take a full 24 hour day if a 12-7 is near flattened….If it’s a crude red/green one sometimes the charge light stays on regardless.It doesn’t mean the battery or charger is duff…..You need your meter to test that.
Your Torpedo-850 jaunts will have have used up a 12-7 battery in 10 -15 minutes.
That was the clue to the chap whose souped up speed controller kept going into thermal shutdown.
I measured his battery after a short sail and it was at 11 volts, ie flat.
Measured a fresh fully charged 12-7 battey before installing and that went flat in 15 minutes.
Third battery went in with an in-line resistor in the power line ( to read the amps by a voltmeter) and it demonstrated the model was drawing 45 amp on a Mabuchi 750 motor….He had, previous week ,taken out the gearbox thinking it would make his model faster.
He wasn’t too sure I was taking him for a ride so he put a smaller prop on……the amps fell to 35 and the boat went noticeably faster.Repeated with a smaller prop and the amps went down to 20 but the boat was then so fast he borrowed a 6 volts 10 Ah with added ballast where upon he still had his much improved speed and was now drawing 10 amps off the 6-10 battery when he started the day slower with 45 amps from a 12-7ah battery.
I kid you not !….He improved efficiency by 800 by matching his electric motor with the best loading.
In the end I tweaked the speed control’s trimpot so thathe got 50% at full stick and he got two hours out a 12-7…….You will get exactly the same effect.
When smaller props begin to reduce speed you have gone back to the point where the motor is at 50% efficiency and the revs will be up to 5,000+
If you did that with 2 60 mm 4-bladers yould empty a bathtub over a bathroom floor.
I don’t know what that does to the appearance of the boat but a previous mentioned diy gearbox with the original props will do the same thing and keep the bearings happy.
A typical multimeter will be destroyed if you meter your fuse busting currents.A DMM is not fused above 2 amps.Best follow my earlier recommendation of setting it to millivolts and measuring across the fuse or 10 cm of wire until you reckon your current is 10 amps.You can at least see how the second prop does in comparison to the first.
Tom
