Not sure if this is the correct page at all to put this on as I am fairly new here. If not, please let me know. Anyway, here goes.
If anyone out there is interested in making their own lathe, then I would like to suggest you go to google.co.uk. Type in http://www.lathes.co.uk and on the main page of this site, scroll down to "f’only" (you should find a list of lathes in alphabetical order). Click on this and you will find full instructions on how to make your own lathe. I am in the process of making one and do not think it is to hard to make, though I do have to admit to working in a machine shop. What you will need are some flat, solid bits of wood – I have found pine to be best – bits of old MDF, some scrap metal (if you know of a local machine shop, try them, {not me!} they are usually helpful) a Dremmel – or similar – drill, screw, nuts and bolts from diy store – patience and trial and error and eventually you will have a reasonably accurate and handy little lathe! The plans for it are in the public domain and it makes it clear that anyone can use them so no copyright involved. The longer you take making it, the more accurate it will be. There are also plans for a drill which works on the same method. i,e., wood etc. By the way, "f’only" stands for – "if only" I had a lathe! Clever people in more ways then one out there! Anyone starts to make one, please let me/us know how you get on.
Ron.
