Help needed with first project
Home Forums Beginners Help needed with first project
  • #47440
    Barry Cole 1
      @barrycole1
      I am just starting on a model "boat", after 20 years with model aeroplanes.
      I want to build a radio controlled Duck. (Quack Quack type)
      I have a small 1000Kv brushless motor that I think will drive the prop ok, with a 2S lipo battery.
      Where can I get a suitable ESC, that will give me reverse from the Transmitter.
      What sort of angle should the prop shaft be to the waterline?
      Has anyone built one of these. I have a decoy duck to start off with.
      cheers BC
      Edited By Barry Cole 1 on 07/03/2014 20:58:53
      Barry Cole 1
        @barrycole1
        #47442
        Amy jane September
          @amyjaneseptember49770
          Hi Barry.
          Welcome to the forum.
          For prop shaft angle I try to stick to less than 15 degrees, although any thing up to 20 would work fine on a decoy. As for a reversing esc I don't know, but some one else will! (I see a lot of ducks around where I am, don't often see them swim backwards though!surprise)
          Stick your build on the forum, I'm sure we'd all love to see what you're doing!
          Amy jane
          #47446
          Barry Cole 1
            @barrycole1
            Thanks for that, I will see how that fits together. Will be a slow build, as it has to fit in between the glider building…
            BC
            #47452
              Mtronics do a suitable brushless marine ESC.
              Aeroplanes seldom need reverse, the car people seem to want to use brakes on the way to reverse, with a boat, reverse IS the brakes. The different play areas do have different requirements, so for boat use its best to look for one designed by people who understand the difference.
              #47672
              Barry Cole 1
                @barrycole1
                Well, I have had 3 goes at getting a suitable ESC, and failed miserably. Still cannot find one that will do reverse.
                So, if one of you kind people could help, I am looking for brushless, 2S, Max 20 Amp. and REVERSE.
                Could someone give me a link to the right place and right supplier.
                Thanks in anticipation.,
                smiley BC
                Edited By Barry Cole 1 on 18/03/2014 20:26:40
                Edited By Barry Cole 1 on 18/03/2014 20:26:53
                #47673
                  Hello Barry
                  Try the Vintage Modeo Boat Company for a matched set
                  Gareth Jones
                    @garethjones79649
                    Hi Barry,
                    Here is a link to the Mtroniks one, rated at 30 amps, as suggested by Malcolm Frary.
                    There is a smaller version rated at 15 amps.
                    Gareth
                    Edited By Gareth Jones on 18/03/2014 20:54:06
                    #47675
                    curly
                      @curly
                      Hi Barry
                      I have built lots of funnices in the pass, myself I go with Bob vintage do a small brushless matched pair and they will be ,only to pleased to give you advice if it goes txxxs up. You can have great fun with a duck, the kids come up and try to feed them. The best of luck with your build
                      Curly
                      #47676
                        Here is the link to Vintage Model Boats…
                        Barry Cole 1
                          @barrycole1
                          Thanks to you all for the replies. I have ordered one from The VMBC.
                          Now I have to insert the prop shaft up his back passage.
                          Thanks again BC
                          Edited By Barry Cole 1 on 24/03/2014 12:57:01
