Motor KV = rating of motors (usually brushless) in terms of speed per volt applied. Don't quite know where the K came from; it usually indicates a factor of 1000, but motors are rated in full terms e.g. a motor of 1100 KV will turn at 1100 revs per minute for each 1 volt supplied (so it will do 4070 RPM from a 3.7v LiPo cell)
Load current = current drawn under load e.g. for a motor this will be the current drawn from the battery with the motor running a propeller in the water.
Miiliamp Hour = unit of battery capacity. A battery with a capacity of 2300 Milliamp.Hours (maH) will supply an average current of 2300 milliamps (or 2.3A) for one hour.
Ampage = Should be Amperage and is another word for current.
Etc = Latin words "et cetera" meaning "and other things". I don't think the Greeks had a single word for it either.
Suggest you get hold of a copy of the most recent Model Boats Winter Special. There is a long article in there covering all of this stuff in much more detail.
