Posted by Peter Vinton on 19/02/2016 16:36:08:
…. I've ordered an Emax 2822 with controller, it's only £10 so seems a cheap bit of fun. And yes, I'm not particularly interested in scale speeds, I want it to take off over a wave!
A major design consideration for EeZeBilts is 'a CHEAP bit of fun'!
I think that Emax offers a good introduction into the world of brushless motors but note that it's not only the motor that will give you the performance you want.
First, note that 7.2v is on the low side for this motor. It is designed for 2-3 cell Lipos – which is around 8-12 volts. So you can up the power quite easily, so long as you consider how the motor might be cooled…
Props really do make a huge difference, especially in small sizes. If you can experiment with different props you will see this…
'Talking off over a wave' is going to be dependant on weight as much as power. You may well find that swapping your NiMH for light Lipos (particularly a small cheap 3S) will make the boat into a rocket. At this point torque and stability start to become important considerations…
