Vic Smeed’s Silver Mist
  • This topic has 842 replies, 5 voices, and was last updated 3 days, 2 hours ago by Colin Bishop.
Viewing 25 posts - 326 through 350 (of 843 total)
  • #66170
      Thanks Paul
      It works well too!
      How`s the car?
      Gorra go!………Footy time!
        Now we come to the rudder space……….As feared earlier……..Not much room
        Head scratching time once more……..ie…..The fun part
        Back shortly……With a solution
        #66189
        Ian Gardner
          @iangardner62867
          Hi Bob,
          On mine, I made the deck right back to the pencil hatching removable and made the aft part a grating, aft of a companionway- all removable in one piece. That way you get a bigger opening but still have a reasonable sized structure on deck. It helps with access to the rudder head.
          #66197
            Thanks Ian
            I fancy the plastic chain idea, at the moment
            Results and pictures shortly
              I use those plastic tiller bars, the ones with a clamp arrangement (the common sort you get with the small med and large size brass rudder assemblies (tillers available separately). These can be adjusted (having replaced the standard nut and bolt for a 3mm bolt and nyloc nut) so that there is sufficient grip to operate the rudder ok, but the rudder post can still be pushed in place. This means that you do not have to have sight of the tiller post as you can fit the tiller by feel. It is also dead easy to adjust the rudder angle afterwards, just hold the tiller and tweak the rudder
              ​No hatches necessary therefore, no chains or anything complicated. Yours is a big craft so loads of hand room at the rear.
                Thank you, Ashley
                Can't really replace my existing setup at this late stage
                Have been away for a few days, so progress is a little slow at present
                  Here we go……. A rudder mech for confined areas!
                  Easy to install and easy to adjust
                  The drive sprocket is a clampable friction fit on the servo
                  #66224
                  Ian Gardner
                    @iangardner62867
                    Hi Bob,
                    What advantage does this system have over a normal arm and linkage arrangement? Seems to me there's more to go wrong.
                    #66226
                      Hello Ian
                      I started out with the intention of going the old arm and linkage method
                      The gears were going to be the hubs for the pivot arms, then the chain idea clouded my thoughts!
                      I like the sprocket and chain idea though
                        Bob. The chain drive would have been most appropriate on the G.E !!
                        Try a nylon tiller next time, they can easily be fitted by feel only, and are a doddle to adjust later on when testing. Ashley​
                        #66229
                        mike farrell
                          @mikefarrell21522
                          Hi Bob you never cease to amaze me with your thinking ,up there with Gareth for innovation .Well done bosswinkMichael
                          #66230
                          Ian Gardner
                            @iangardner62867
                            Hi Bob,
                            It looks nice and technical and why not? Is there much backlash in those gears and chain linkage?
                            #66231
                              Thanks, Ashley
                              Thanks Mike……..Long time, no see!
                              Pleased you like the unconventional!………..It makes for an interesting thread
                              Keep popping in…….Regards to the missus
                                Hello Ian
                                If backlash causes a problem, I can always fit a jockey pulley
                                I'm pleased you like the idea afterall
                                  Hi Bob
                                  Back from Spain, great time there planning future projects, kept up with your progress with my Tablet while sitting by the pool, tough life but somebody has to do it ! Your rudder chain linkage is taking the project to the next level, where do you get your sprockets & chain ? I thought it maybe a better option to a running line on my sailing barges sheets.
                                    Hello Ray
                                    Welcome home…….Hope you didn't watch last nights football travesty!
                                    I'm pleased you like the latest offbeat rudder feature, with the chan drive
                                    The chain came from Hobby's Ltd
                                    I fitted a chain drive in the Louis Heloise to activate the sails
                                    The sheet anchors were simply clipped on the links
                                      Hi Bob
                                      Yes I had the TV on in the workshop, I listen to it rather than watch, out of Europe twice in one week !
                                      I like the chain idea
                                        Just a charming picture of the chain mech for the happy band of impatient followers
                                        The spotlight is rather twee and only a £1.00 from the local bargain shop
                                        Oooops……where`s that picture gone?
                                        Later…….Found it
                                        Edited By Bob Abell on 29/06/2016 10:12:22
                                        #66249
                                        Ian Gardner
                                          @iangardner62867
                                          Looks very neat Bob- I'm a convert!
                                          #66257
                                            I must agree with Ian's comments – It's excellent.
                                            Tony
                                            #66259
                                              Thank you, Ian and Tony
                                              Your encouraging words are much appreciated
                                                Nice detail Bob and I especially like the spot light wink
                                                #66268
                                                  Thank you, Paul
                                                  Nice to see you again
                                                  The mini lights are really twee, but nicely made
                                                  Must get a few more for that special photo coming up shortly
                                                  Banjoman
                                                    @banjoman
                                                    Bob,
                                                    Please let me join in the praise of the previous recent comments on your ingenious and interesting solution to connecting up rudder and servo — your admirabell idea is duly noted and filed away for future reference!
                                                    /Mattias
                                                    #66270
                                                      Many thanks, Banjo
                                                      As already mentioned, the idea came by accident, when trying to make use of a pair of plastic gears, with the intention of turning the teeth off and using the hubs!
                                                      You could perhaps incorporate the idea into your Moonbeam build…..As the winch drive and rudder mech?
