Vic Smeed’s Silver Mist
Viewing 25 posts - 301 through 325 (of 843 total)
  • #65943
      Hello Ian. it was only an idea that solved the flimsiness of the wings and not really a serious proposal
      I liked the idea of the gussets being painted to match some painted areas on the top cabin though
      I've since moved on, with the top cabin parts being cut out and propped up in position
      However, the air temperature at the moment does little to encourage much serious construction work at the moment
      Don't think Ray will be as hot, sitting on the harbour wall, somewhere in Spain, imbibing a suitable refreshment?
        Just a work in progress picture to keep the interested parties up to date with the latest idle chat
        Everything is in the melting pot at the moment and I`m just weighing up the situation
        Making great strides now, but don`t want to depart too far from Vics design
        Access to the motor drive, calls for a drastic mod to the main deck area
        #65953
          Here`s a useful tip for cutting out window frames
          Grip a coarse grit rotary drum in the vertical drill, then use both hands to clean out the openings…..Easy
          The wood blocks are not tart of the exercise btw
          #65971
          Ian Gardner
            @iangardner62867
            Hi Bob,
            It's how I do windows- but I use a Dremel in a router table. Having just got a Proxxon saw table, which is brilliant, I'm highly tempted by their micro shaper, as it's great fun to make little mouldings with miniature router bits. The Dremel table isn't very stiff.
            Are you going to stain this ply or overlay it with veneer or thin sheet? I have used 1/16th mahogany from SLEC over liteply which makes a nice stable lamination, and the thin sheet is easier to apply than veneer- if you can even find mahogany veneer. I'll be interested to see how you proceed.
            #65973
              Bob. I don`t do windows very often but I will file away that little gem, useful.
              ​Access to motor drive most important, and if it means departing from Vic`s design a little bit I am sure that will be quite acceptable.
                Hello Ian
                I think veneer may be the best option or even the humble Fablon?
                I may paint the top cabin and window frames
                The rudder mechanism appears to be a long way out of reach at the rudder end?
                  Hello Ashley……Only just spotted you
                  Pleased you like the window trick……..It does make life more bearable
                  Wouldn`t it be nice, having a 3D Printer to make a few custom window frames?………And other little trinkets?
                    Hello Captain Bob
                    Does this mean that you are treating yourself to a 3D printer?
                    #65988
                      Don`t think so, Paul
                      The learning curve will be too great, but it would be very handy at times
                      I`ve heard that the cheap eye catchers are cheap eye catchers
                      Not seen one working yet, but hope too see an example at one of the shows this year
                        Work in progress
                        Seems a pity to cut through the main cabin roof, as Vic decreed?
                        Time for a cup o` tea and a think
                        #66013
                          Rear access openings
                          The large opening just about misses the motor drive, so the cabin hatch is required afterall
                          Access to the rudder is a bit awkward too
                          #66066
                            Have finally assembled and glued up the stand
                            Now`s the time to stand well back and look for trouble!
                            Have placed a straightedge across the deck and I`m looking for anything out of line etc
                            Luckily, all seems to be in order
                            Have decided to install the motor gear and propshaft etc next, before the cabins are glued in place and make life difficult
                            Then probably seal the hull and do a few buoyancy and floatation tests in the garden pond
                            That sounds ok to me, mates?
                            IAN_I
                              @ian_i
                              Hi Bob…I have been watch the build and it looks great.. best regards Ian
                              #66084
                                Many thanks Ian……I like to know who's looking in these days
                                Just having a look at the motors and ESC' s I have in the surplus stock drawer and now thinking, I ought to make use some of this modern stuff from previous recent ventures……Mostly brand new too and abandon the old junk?
                                I'll have an in depth technical meeting…….After the match
                                  Captain Bob
                                  Is it an optical illusion or are the portholes on the R/H side lower than those on the L/H side?
                                    Hello Discerning Nitpicker, Rivetcounter cum Troublemaker, Quality Control Officer……Ad Infinitum
                                    Nice to see you are checking my work!
                                    They are probably not in line……Can't imagine what I used as a reference at the time?
                                    Good job the holes are undersized at the moment?
                                    It's going to be a tricky job deciding what's what at the moment, as you can imagine
                                    The deck is probably a good starting point, when I get round to it
                                    At the moment, I'm fiddling with an ex Brutus motor set…….The one fitted for the Lyme Park run
                                    But the big old MFA motor looks more in keeping
                                    We have a special regatta coming up at Etherow, end of the month and I hope to give Lady Joyce, a run for her money?
                                      Bob. It is a big boat. Install the most powerful motor, there is loads of room to swap them if reqd??? The MFA motor only needs to be roughly in line using a double coupling if it was the second motor to be tried, easy.
                                      ​Re portholes….make a note….do not photograph anything square on!!!!! Notice the arty pictures in any and all of my articles…are any of them square???…..wink
                                      Ashley (Not that any of my boats/cars/planes etc ARE wonky or have dodgy dubiously aligned bits, but sometimes the fall of light gives the wrong impression…know what I mean ??)
                                      #66116
                                        Thank you, Ashley……I know what you mean, but the photo was meant to show the effect of placing the straightedge on deck, to highlight any discrepances
                                        Lucky for me…..There were no glaring cock ups!
                                        It`s a visit to Specsavers now, for Paul, I`m afraid?
                                        PS……..Photoshop is a lifesaver at times!
                                        #66125
                                          .nerd…….Look closer…..nerd.
                                          #66127
                                            Give me clue, please
                                              Look closer
                                              #66130
                                                Captain Paul
                                                In what capacity have you spotted the so called blunder?
                                                Nitpicker
                                                Rivet counter
                                                Quality Control
                                                Need a clue, old chap
                                                  Here`s something to brighten up the day and have a laugh!
                                                  Lashed up the old MFA Marlin motor drive in order to check the system and it`s turned out…….Quite nice
                                                  I`m pleased that it runs like an old sewing machine
                                                  Also pleased that the antique speed controller is up for it too………For the time being at least
                                                  When it stops raining, I`ll try it in the pond, to test the system for the required splash factor and put the controller under a bit of load
                                                  I am aware that the setup is quite ghastly, but it is keeping with a model from yesteryear, using bits and pieces from the junk box
                                                  #66168
                                                    Well, it`s finally stopped raining and the pool was splendid………Nice colour too?
                                                    Lady Joyce took the pictures
                                                    The test rig behaved nicely and put on a good splash……..We can now proceed with confidence
                                                    The vintage speed controller seems OK to me
                                                      Hi Bob
                                                      That's a nice milk shake mixer
