I didn't go boating last week as of course it was Remembrance Day and I was attending a service, playing as it happens this year in Redial !
This week it is dark, windy and currently spitting with rain, so will give it a miss, cant see things improving any.
This weeks boatbuilding is concentrated on the Titanic`s box. This is far too heavy and solid, and was designed for show as much as simply storage. It is 2 inches taller than it needs to be, so I have scrapped it and am making a new one….18mm ply base, hardboard sides/top.
This will accomplish two things: one, it will fit on different shelves easier and two, will make carrying the thing much easier, leading to improved sailing rates, hopefully.
On the last outing of the Midge, she cut out three times, cause not apparent at the pond. I have had a better look and there is nowt to see! I re-seated the various connections and pulled the ends but all is well. I think I will change the Tamiya connector on the ESC to a Deans….this will match all my batts and will not need a converter lead, another source of unreliability.
I have very few craft will complicated wiring. The Alvis is probably the worse for spaghetti, as there is barely room under the rear cargo deck for the stuff and everything is jumbled up, made worse by having a P94 Action mixer ESC and a power board which requires more wiring than simply using one ESC with BEC. Unavoidable here as the thing has no rudder and so has to have prop steering. One other craft has differential control but uses aircraft ESC for lightness and a V-tail mixer, and on this one there is plenty of room.
I should really finiosh something I started years ago, the Turbinia. The hull is done, propshafts in……the big decision is on the motor front…brushless nowadays due to all the props, and weight of course, but will mean 3 ESC….can I gang that many together on a split lead on one channel?? I suppose so….?
