Hobbyking sold the Hornets, I think the outboards had problems with flex drive and Hobbyking did not kept spare parts.
I have an outboard from the F3 cat, great outboard but no spare flex drive and an Aussie hobby shop has the spares.
They doubled the price in one hit last year, so $20 AU + postage, no way!!!!
So like you it's going inboard with the same motor (28mm 3000kv) with a 4mm flex drive.
I have all the bits squirreled away.
I start back on the Sea Raven ( the one with the project hole in the stern.
The false stern plywood had is first coat of marine mast vanish today (min. 48 hours between coats and 3 coats required).
Getting close to spring and the weather is getting better.
When to my test area for the weekend, three days of good weather and model boating.
Tested more props on the Sea Commander, but, ended back with the start prop.
Only got two more props to test, a 3 blade alloy 37mm (I think it will cause too much prop torque) and the 2 blade 40mm alloy prop from my white ocean racer.
I am happy with the D3548/4 1100kv 910 watt motor quieter, more powerful and cheaper than the 3639 1100 kv 800 watts( $5 AU cheaper).
The D3548 is rear mount with an inbuilt prop like blades for cooling, I ran the Sea Commander flat out until the battery alarm went off and the motor without water cooling was touch warm on a 16 degree day.
The car ESC was cool .
As for the Seahawk the setup in my Sea Hornet would give it a bit of zip!!!
Harry the Larrie-kin
