Fiddled with the Top gear Hovervan a few days ago. Since the change of fan blade in the 75mm EDF unit (providing lift), the thing had become embarrassingly noisy. Not out of character of course in this case. Seems to be vibrating a bit and of course the vehicle is one massive sound box
The unit was a plain cylinder with a central flange, and this was dead easy to munt in a hole in the box in the middle of the floor, it just sits there on the flange , held in by a couple of ply "flaps"and self tappers.
This unit was chosen for its power, but I have a couple of 70mm units (with smaller motors), and they run very sweetly…I have decided, after experience by the using of, that I don't actually need that much lift power to achieve the desired result and so have fitted one of the 70mm units.
These have a "bell" intake end and no flange and are made from a very smooth plastic. I ummed and arred as to how to fit it in…but at the end of the day simplicity won out and a new hatch was cut with a smaller hole to suit the EDF, and the unit has been held in place with silicone sealant, This sticks nicely to the smooth plastic casing (roughed up a bit with sandpaper) and is slightly flexible to assist vibration dampening.
I have not tried on the water yet, but it is much quieter, must consume less current (half at least according to motor spec) and I have no doubt it will make the van perform as before with no probs.Result.
Work goes on apace with Proj No3, and I am having to freehand hand-paint the windows, as I cant see another easier or more accurate method due to the shape and construction (wait until you see it and you will know what I mean). Looks ok so far, not very close up perhaps, but from a normal "table" viewing distance is fine. I have just done the silver frames now, I can make templates to outline the inner windows with a fine indelible black marker pen before painting them black, a method I have used a few times and one which produces nice crisp shapes
If it is a nice day, then Proj no1 will debut on Sunday, I just need to fasten the flaps on, and charge the camera batts !!
Edited By ashley needham on 26/05/2016 09:47:31
