WELL, Nice crisp sunny day at the pond.
Titanic, Hornet..going well and teh DUCK all had an outing. However, I have a numb fingy now after breaking ..something..on the Duck..I do appear to have an intermittant 7.2v batt, and having connected it (this was for the second run) the DUCK did not work and so I reached in to twiddle the battery connection and.. ow!! Need a trip to Mich Charles models to order another THING and a spare. Easy job to replace though..hopefully..does not need an engine out, a one screw job.
Trevor had the monster corvette down for another quick float (and a tow from his small tug..very amusing) and we spotted only two v small leaks. However the ballast situation may need a rethink on the milk bottle front (filled with gravel this time) as there MAY not be enough room for enough cartons and so some lead, or whatever may be needed. A bit like my Lotus..after all that work on it there was not enough room to fit sufficient lead inside and I had that horrid stomach sinking sensation that possibly I may have erred and the thing would never work…
He has loads of room though for lead if thats what it takes, it is more a case of getting the best combination and location rather than oh! help and lead is expensive.
Andy Ray Ian Barry Chris down. Ray had his big thames barge down, and nesting in the hold was a v small thames barge !! 12 inches possibly overall.. very sweet and its first outing, and indeed a successful first outing, just enough breeze and showing more than adequate stability. The real test will be in a bit of wind, but we will see!
A prop from Andy`s tine hydroplane fell off (flexishaft broke) but by a spot of good fortune was spotted glinting in the sun just three feet from the jetty, luckily again the water is very clear. Andy donned waders and retrieved the prop. We had cameras ready but unfortunately.. The purchase of the waders even just for this one recovery have probably just paid for themselves (Berylium super duper prop)
Finger regaining sensitivity now, offending item off and I shall be surfing for a spare soon.
Project no5 coming on, at the "splashing on some paint" stage and things are looking much better, covering all the glue and filler in a uniform grey (undercoat) and restoring a bit of order. Motors and props have been fitted and the various openings and so on glued up and possibly next week i may be able to have a float ! A few details for the underside have been added and when painted these will look quite adequate. I am having to make these bits a bit larger than they should be so they will stand up to underwater..accidents..with logs and so on. Also need to keep these to a minimum to minimise drag, I dont have a lot of power to play with as eventually you will see, and the propulsion set up is a bit unusual, and may be less than efficient, but the item is not meant to be particularly fast.
