can you be.ieve it th3 weed had blown over to the jetty overnight, which scuppered a yot and a speedboat but didn’t stop me try the new one on the side stream.
Basically the boat went ok with the new motor on 2s and with the spray rails, on the twice cut down prop.
Extra “filler” foam although perhaps providing a minuscule performance increase made the boat visibly more tender and the full size prop, although definitely providing a slight performance increase flipped the boat over twice (once with and once without the filler) although the prop did not contact the water, it was just the increase in prop torque.
I think this is as good as it gets so I will paint it now, and further experimentation will be limited to ballasting and swapping props. Perhaps a bit more oomph will be available by cutting down a 7 inch prop to the same small diameter, As this will give me more blade area.
