Vic Smeed’s Silver Mist
Viewing 25 posts - 751 through 775 (of 822 total)
  • #70645
      Well!……Would you believe this?
      The Lake cafe has just installed a WiFi signal at Etherow
      So, hopefully, you will be getting a very novel live report on the maiden voyage of the Silver Mist
      We are looking forward to this, boys!
      Bob and Duckie ………Outside broadcast services
        Don't think so, Ray
        See the bath test post…….20 lb should do it?
          Good news, chaps
          Silver Mist sailed well today
          Duckie at the helm……More pictures to follow shortly
          PS…….Picture is just orbiting Jupiter at the moment !
          #70652
            The long lost picture, finally emerges
            She's a bit high in the water with only 12 lb of ballast
            Had a lovely diesel engine sound, caused by a slightly bent prop shaft
            We are sailing
            #70653
              Its a very pretty model Bob and only you could spin a bit of bad news like a bent shaft into a nice diesel sound.
              Did Duckie get any video?
                Thanks Paul
                Duckie is preparing the video right now
                Decide for yourself, regarding the diesel sound when the video is published
                We had a very pleasant sail this morning and was very pleased with the model's appearance and pleasant docile sailing performance
                It was great fun, dodging the yachts
                The rudder may need increasing in size, for a quicker response
                The club members were in raptures when they saw the odd looking motor drive, fan unit and chain drive to the rudder post
                But got away with it, since the model was a vintage Vic Smeed creation
                  A few more pictures for your interest
                  Dodging the J Class yachts was great fun
                  Bob and Duckie
                  #70658
                    More lead required
                    Silver Mist was nose down on first launch…….So it was all hands on deck!
                    Which was great fun
                    #70659
                      Looking through the windows, should have brought the crew?
                      #70660
                        Unusual picture
                        Such dark water on a sunny day
                        #70661
                          Final picture………Just cruising
                          Video to follow
                          #70662
                            Ha Ha……Duckie has done us proud with a very nice informative video
                            Many thanks, my mate, for your help today
                            Here comes the Vid…….
                            Bob and Duckie
                            Excellent video, but can`t get the link active?
                            Edited By Bob Abell on 18/04/2017 18:47:28
                            Edited By Bob Abell on 18/04/2017 18:49:33
                            Edited By Bob Abell on 18/04/2017 18:51:08
                            #70666
                              You are right about a boat engine! that propshaft clicking sounds like an old single cylinder Lister that I used to own.
                              Edited By Paul T on 18/04/2017 19:29:19
                              #70667
                              Ducky
                                @ducky
                                Edited By Ducky on 18/04/2017 19:46:08
                                #70669
                                  Very impressive Bob. Quite a large model which looks very impressive on the water and looks to be in keeping with a scale speed. I am sure you will sort the prop shaft issue, although it does add a sound effect which many would buy an electronic box to re-create.
                                  Tony
                                  #70670
                                    Coming from model boats leading Vic Smeed expert…..That's praise indeed
                                    Many thanks Tony…..That's good enough for me matey
                                    Banjoman
                                      @banjoman
                                      Congratulations, Bob!
                                      A both pretty and interesting build that sits really nicely in the water! I take my hat off to you, Sir!
                                      Mattias
                                      #70682
                                        Many thanks Banjo
                                        I can now finish the model off with confidence, with the knowledge that the model sails ok
                                          That extra 2lb of ballast certainly seemed to make a difference. Thanks for posting Ducky.
                                            Bob, well done. Shame about the racket, but these things happen eh?? cant be that much wrong (unless it is your fan bashing the snazzy fan casing !!)
                                            ​Ashley
                                            #70703
                                              Many thanks Ashley
                                              The propshaft is made up from scrap parts and is of extra length, with a coupling in the middle and a bearing block
                                              The shaft has a slight whip and the bearing block was allowed to flex, as it was not secured
                                              I have since corrected the rattle now
                                              I enjoyed the maiden voyage though
                                                A photo of the nameplate, for your inspection and approval, Kevin
                                                #70783
                                                  Kevin
                                                  Just letting you know that the Silver Mist is still being finished off, but is back in sailing mode, whenever
                                                  At the moment…….Baby, it`s cold outside!
                                                  PS…….The motor has been fitted with a silencer……ish
                                                  #70784
                                                      Was the 'silencer' whacking the shaft with a piece of pipe? wink
