Vic Smeed’s Silver Mist
  • This topic has 842 replies, 5 voices, and was last updated 2 days, 5 hours ago by Colin Bishop.
Viewing 25 posts - 601 through 625 (of 843 total)
  • #67463
      You may have overdone the sanding there, Bob.
        Hi Bob
        SM is looking good, any chance you'll find an owl & pussy cat for crew ??
          Thanks Ray
          "The Owl and the Pussy in a Pea Green Boat"
          I didn't get it at first!
          Diede van Abs
            @diedevanabs87670
            Hi Bob,
            I like the darker color green in your photoshop examples, also the darker cream stands out more if you'd ask me.
            Please DO sand the hull better, though. The blemishes are all too visible now, it actually makes the boat look like a very, VERY badly done fiberglass one. I think you can do better than that.
            #67485
              Thank you, Diede
              All in good time
                I know that Bob knows that the hull is a bit rough and could do with a bit of sanding, but he is happy for the moment and that's ok.
                The point here is that Bob KNOWS it needs sanding but is prepared to leave it for a bit.
                How many models have I seen where the owner has not sanded their bits sufficiently, and the finish is substandard, but either the owner does not care or just does not see it as substandard.
                I can`t claim to be a perfectionist, but a few more minutes with a bit of wet`n`dry or sandpaper is all it takes to get a reasonable finish as opposed to a horrid surface that most people would look at with distain.
                I saw a German battleship of some description (somewhere shall remain nameless) that the owner had built plank-on-frame, and had purchased and /or made all the detail bits and it looked quite nice. BUT when you looked at the hull….all the planks were still visible !!!! ???? 20 mins sanding was all it would have taken.
                The thing is,,,do you tell someone to get the sandpaper out….can you do it on the forum ? or do people get the hump?? Like Bob, I know what's wrong with my models and don't mind constructive criticism.
                  Many thanks Ashley
                  You have put the situation in perspective
                  Can you imagine, if a person, looking at a newly posted model, decides to draw attention to the paint finish?
                  It`s the height of bad manners and would certainly cause offence
                  I can always retrace my steps, when the paint has hardened off where the potholes and defects will stand out more clearly, after sanding
                  There`s plenty of more interesting work yet to be done
                    Hello Captain
                    Maybe the members cant understand why you, as an highly skilled model boat builder have decided to work out of the traditional sequence. You have in the past expressed your willingness to accept constructive criticism and this certainly falls into the category of constructive criticism.
                    For those of us who might be new to this sanding/painting lark it might be an idea to explain your thought processes, I can understand using paint to show up any imperfections before a final rub down and I took your painting to be a variation of this process.
                      Thank you, Paul, for suggesting I`d got a cunning plan for the painting process!
                      There`s nothing scientific in the process at all!
                      If you remember, I started painting the hull, just before the Haydock show and wanted to be sure of the colour scheme and imagined, I`d need a few gallons of paint!
                      That`s all
                      Ha! Ha!
                      And besides………You know the real reason!………More laughs
                      Look after yourself, my mate
                      Edited By Bob Abell on 02/09/2016 15:05:36
                      #67495
                        Tho trouble is, if no one draws attention to the unsatisfactory finish in anyone's boat, then the owner/newbie/whatever may be under the impression that they have achieved a satisfactory finish? Certainly I have seen some efforts on the forum and everyone says "yes that's nice/great first time build/like the thingybob at the rear" etc etc and what we should be saying is….yes good effort BUT….or how else is anyone to learn?
                        ​Ashley
                        #67498
                        mike farrell
                          @mikefarrell21522
                          Hi Bob As all will observe I have not passed comment re. your painting .The reason is having seen at close hand I know the very high standard you finish your models .
                          So patience is an admirable stock to possess .
                          So folks lets wait for the finished article ,it will be a successwink Michael
                          #67499
                            Hello Mike
                            That`s very kind of you to say that, but I don`t really finish to such a great finish as you suggest?
                            I think the finished article may give that illusion?
                            Did you get to Haydock this year?
                            Nice to see your post
                            All the best……..Bob
                            #67508
                              Hi
                              The original boat may be was painted with a brush as the full size boats were and as finishing a working boat to mirror show room misses the point .
                              A bit of rough adds a bit of real life to a boat.
                              #67512
                                Thank you, Harry
                                My sentiment entirely
                                That's what I mean……We don't want it looking like a fibre glass hull
                                Welcome to the forum
                                  Just in case anybody was wondering about the lack of postings……..
                                  We have been on holiday in Barmouth for the last few days
                                  Normal service will be restored shortly
                                  Banjoman
                                    @banjoman
                                    I had indeed begun to notice a certain Abellessness on the forum, and am glad to hear both that normal service will shortly be resumed and that it had been temporarily suspended for a nice reason
                                    Mattias
                                    #67594
                                    Ian Gardner
                                      @iangardner62867
                                      Hi Bob,
                                      Hope you had a good holiday- and yes, I too was wondering where you had got to. Looking forward to seeing more progress on your Silver Mist.
                                      All the best,
                                      #67629
                                        Thank you, Banjo and Ian for your understanding patience…..And as a reward, you can be the first to see the latest offering
                                        Rear of cabin veneered and a new fangled sliding door fitted………I`m sure, it would get Vics approval
                                        And before you start…….The screws are only temporary……..Will probably fill them in shortly
                                        #67644
                                          Further cabin work
                                          Windows glazed and sliding door tidied up
                                          We are slowly getting there, chaps
                                          #67647
                                          Ian Gardner
                                            @iangardner62867
                                            Looking nice Bob. The colour scheme looks good with the bright wheelhouse and capping rail. The sliding door looks the biz too.
                                            I spy filler! This was your cunning plan all along.
                                            All the best,
                                            Edited By Ian Gardner on 13/09/2016 20:16:11
                                            #67653
                                              Hello Captain
                                              Your latest model has very nice proportions and 'sits' very well and should look great on the water…….. despite the rustic paintwork.
                                                Thank you, Ian and Paul
                                                Pleased that we like the green and cream paint scheme now
                                                And Ian has spotted the filler work
                                                Paul likes the general appearance of Silver Mist, but the credit goes to Vic Smeed really
                                                It's really too hot to get much done today, chaps
                                                Ian Gardner
                                                  @iangardner62867
                                                  Although Vic Smeed was a very clever designer I think most of the credit in this case should go to John Bain who was the designer of James Silver Yachts of which this is one example.
                                                  #67674
                                                    Hello chaps
                                                    A few more pictures telling the everyday story of the model boat builder
                                                    Varnished the top cabin and is quite nice
                                                    Those Liquorice Allsorts on the deck are in fact, small blocks of a foam sander……..Very handy for getting in the crooks and nannies!
                                                    Still not got any brass wire for the handrails………A treat, yet to come
                                                    Banjoman
                                                      @banjoman
                                                      This continues to look very nice indeed, Bob!
                                                      Are you planning any interior decoration work for the visible parts of the wheelhouse?
                                                      Mattias
