Vic Smeed’s Silver Mist
  • This topic has 842 replies, 5 voices, and was last updated 3 days, 2 hours ago by Colin Bishop.
Viewing 25 posts - 526 through 550 (of 843 total)
  • #67167
      The railing height can be calculated by looking at the picture of Vics original.
      The rear railings come up to the sailors waist so a simple measure of your manly physique from floor to belt buckle and a quick bit of mental arithmetic using your build scale will provide the answer.
      smiley
        Thank you, Paul
        The question is……..Was the original boat 48 ft…….In which case, the model is 1/12 th scale making the hand rails, about 3 ft high………3" on the model
        But scaling the plan, they are only 2 ft high………They look a bit too low at 2" on my model
        It's only a Storm in a Teacup, I know, but it's got you out of bed!
        We'll soon find out when installed shortly
        Ps……Just tried the Paul T method and it came to 31"
        So Colin is correct with his figure of 33"
        Edited By Bob Abell on 17/08/2016 18:11:55
        #67169
        Ian Gardner
          @iangardner62867
          I'd hesitate to call my contributions advice Bob! Merely suggestions for discussion.
          You got me wondering about these stanchions so I have just been out, to the boatshed to measure those on my Silver Mist. They are 1.875'' from deck to top of rail and at a scale of 1:16, which is what my boat is, that gives a height of 30''- what Colin initially suggested. Good enough for me and your 31'' will be about right too. Perhaps I went through the same thought processes as you- can't honestly remember now.
          #67170
            Thank you, Ian
            Apologies to all concerned for going on about such a trivial matter
            I can make the stanchions any height within reason, because they are simply pushed in holes in the deck
            A collar will eventually be glued or soldered when the debate finally closes!
              It's not really a trivial matter Bob. The guardrail height is a significant visual cue on a model and if it is out of scale the model won't look right. I had some brass stanchions I picked up a while ago that I thought I would use on my Fishery Cruiser but they were just a fraction too short according to the plan and just didn't look right. I forked out quite a lot for some alternatives at the correct size and they look far better so worth the extra cost.
                That's nice to hear Colin……Thank you
                Perhaps trivial was not the word to use……….I just didn't want to bore the readership any more, with the subject
                  Hi All
                  Late to the great stanchion debate, mine are as the original drawing and the picture of the Silver Vanity on the cover of Model Maker mag. My stancions are the Caldercraft 35mm which are very nice, the capping rail on the top is 2 laminations of 1mm mahogany with holes drilled in the lower lamination. my problem was threading the copper wire through the holes and end up looking decent.
                  #67177
                    Hello Ray………You've not missed much
                    It's all your fault though!…….You said my boat was spot on at 1/12th scale……..And thus far, have thrown a spanner in the works!
                    Only joking, my mate
                    We'll get there in the end, but it does prove the Colin Bishop theory, that scaling up doesn't always work out!
                    We have some sort of confliction between, 1/12th scale and Vic's drawing
                    Have you used the plastic coated brass wire for your rails?……..They always bite at a sharp corner
                      Hi Bob
                      I will try that approach with my next set of rails on the little MTB, but we have all been doing this "for a while" and still find the practical issues get the grey cells moving.
                        Thank you, Ray……The lower rails look true to scale, all suitably bent and buckled, after the kids have finished climbing on them?
                        A little trial run showing the hand rail assembly……
                        3" long x 4mm dia brass tubes, pushed into the decking and secured at the hand rail with tight fitting brass panel pins
                        Seems ok to me…….So let`s get crackin`!
                        #67184
                          Well, that didn`t take long!……….I enjoyed knocking the panel pins in!
                          The swarthy sailor is 5`-10" tall standing on a box
                          The handrails are 33" to the top of the wooden rail
                          They look a bit strange at the moment, because the horizontal rails are not fitted
                          I will have to make a jig to drill the stanchions and then it will look nice………Hopefully
                          #67194
                            This must be the Eureka Moment of the Century, chaps!
                            Apologies for being boastful, but this fixture is full of pleasing engineering features!
                            I needed a fixture to accurately drill about 50 stanchions for the horizontal rails
                            I first gripped a stanchion blank in the drill vice, as a starting point
                            Then an idea twigged…….An angled plate, that can be clamped over the tube, with pilot holes
                            Then wondered how do I get the lateral hole centres…..Dead on?………Mmmmm?
                            The tubes are 4mm dia……..The holes need to be 2mm away from the clamp datum face…….Yep!
                            How do I mark the hole centres……Dead on?……..Mmmmmmm?
                            Eureka!………Use a piece of 4mm hard stainless steel sharpened to a point……As the centre punch!
                            So there we have it……….And it works well too
                            In the photo, the tube end would be level with the fixture end
                            The drill vice has a vee notch on the clamp section
                            Like it?
                            #67197
                              Very ingenious and effective method for larger scales Bob. The pillar drill is pretty essential though as the holes must be at exact right angles to the length of the stanchion.
                                Thank you, Colin
                                I'm pleased you have understood the accuracy of the set up
                                The clever part of the fixture is the method of clamping the tube to the daum side face via the vee block and the accurate method of achieving the pilot holes, using the 4mm dia centre punch!
                                Very satisfying project
                                  Have fitted the minor rails now, just for effect, but the wire is difficult to see at the moment
                                  At least, the holes line up
                                  #67205
                                    Another quik fix to see how the cabin rails will look at 2" high
                                    Hopefully, I can use the same drilling fixture?
                                    Making my shopping list out now for the Haydock Show
                                    Now that the local model shops are disappearing fast…….The Annual Shows are a real life saver
                                    I know we`ve now got the net to supply the modelling stuff, but 5m of 1/16" is a bit optimistic
                                    #67222
                                    Banjoman
                                      @banjoman
                                      Your build continues to look great, Bob, and I was much impressed with your set-up for drilling the stanchions! That one has certainly been fuiled away for future reference …
                                      Mattias
                                      #67226
                                        Thanks Banjo
                                        Hope you can make use of the idea, one day
                                        Engineering problems are great fun
                                          Cabin rails under construction……..(Got no brass wire till the Haydock Show)
                                          Ray and Ian will notice that the hand rails are slightly different than the drawing shows
                                          Have taken the rails round the corner for extra support……Nice eh?
                                          #67237
                                            Hello Captain Bob
                                            The railings look very good……….you could have a nice little cottage industry making these to special order.
                                            Respect
                                            You won't believe what grandson Ryan came up with last week, his nine year old brain has conceived a machine that can fly like a quadcopter, sail on water like an airboat and travel underwater like a midget sub. The best part is that I cant find any reason why it couldn't actually work.
                                            #67239
                                              Many thanks, Paul
                                              I've always said that handrails maketh the model
                                              But if they are not level and true…….The opposite applies!
                                              Hope to see you on Sunday……..Duckie is coming too now
                                                Duckie is coming?
                                                Has there been a change in government or have aliens been sighted over Stockport?
                                                wink
                                                #67241
                                                  Hi Paul
                                                  Duckie has never been to Haydock and has finally succombed to my exciting stories! of yesteryear
                                                    The railings are looking good Bob,
                                                    Earlier in the thread you posted part 1 of the original Model Maker item, parts 2 & 3 were discussed with Ian but never made public. Whilst looking in archive last week, I also came across the two articles from October and November 1958. Thought I would post them as a comparison between your enlarged model and Vic's original 21" (533mm) model.
                                                    #67243
                                                      Thank you, Tony
                                                      Many thanks for the magazine inserts
                                                      I'll read them with interest, when I find my magnifying glass!
                                                      I too, share your interest in Vic Smeeds models…..He must have been a very prolific model maker
                                                      Keep in touch
