Vic Smeed’s Silver Mist
  • This topic has 822 replies, 4 voices, and was last updated 1 day, 3 hours ago by Colin Bishop.
Viewing 25 posts - 351 through 375 (of 823 total)
  • #66273
    Banjoman
      @banjoman
      Bob,
      I did give it some consideration for ther rudder inkage, but as I already have both the how-to and the necessary hardware sorted for a remake along the lines of the existing solution, I'll stick with what I'd already planned.
      As for the sail winch, everything is already sorted there, and just needs to be put back in once I've finsihed painting the hull interior, so a late-in-the-day conversion to a chain set-up should be more trouble than I think it would be worth.
      But, as I said already, certainly filed away for future reference!
      /Mattias
        The motor has a double shaft……..So why not make use of it?
        A cooling fan to waft a gentle breeze across the hot rheostat? ………(speed controller)
        I think Vic would be tickled pink with this feature?
        #66306
          Back on the hull construction now
          Devised a cunning plan for access and cabin removal, which will come apparent shortly……..If all goes well
          Can you see what it is yet?
          #66313
            All is revealed!……….What do we think……..Ian and Ray?
            We`ve now got total access to the control gear………And it looks nice too
            The end curves will be finished off when the cabin is in position
            The top cabin is now a simple glued on structure
            #66314
            IAN_I
              @ian_i
              Hi Bob…
              Really taking shape now, starting to see the size of the magnificent build.
              Best regards,
              Ian I
              #66316
                Thank you, Ian I
                The model is making good progress now and is a very interesting build
                It is a bit big at 48" but wouldn't find it much fun if it were any smaller
                The main problem on the skyline now, is the problem of making the handrails and handrails maketh the model!
                Good match last night?………Well done Wales!
                All the best, Ian
                  No!…….. This is not a Star Wars thread!
                  It`s only me doing the sensible thing, when excessive sanding
                  I have a pet theory, that the glue used in the manufacture of cheap plywood, can only be considered as the equivalent to the dangers of coal dust!
                  So it`s wise to use a quality dust mask
                  It`s only too easy to get stuck in and power sand away without a care in the world
                  I did that last week, without a mask and feel very uneasy about it!
                  I often wonder…….How does dust get out of the lungs?……….It`s a sobering thought chaps
                  IAN_I
                    @ian_i
                    Hi Bob…or is it Darth Vader… ​I thought the Wales match was outstanding. As for the hand rails will you try wire or pvc tube ?
                    regards.. Ian
                    #66322
                      Hello Ian
                      The stanchions are the main problem
                      Don't think they would be made from brass on the full size craft, so I may be able to get some die cast ones and paint them
                      I could even, turn them from hard close grain wood?
                      We'll see shortly
                      Darth V
                      #66323
                        The saga continues as Darth Bob drains the great tea lake of Etherow and prevents the import of Rich Tea from the planet Mackvitie. Will brew time ever be the same again?
                        How will the Bobabble elves make the handrails or will the Imperial Death Star be forced into action without these critical safety items.
                        #66324
                          Welcome back, Jabba T
                          Your imagination is running away with you as normal
                            Progress is good at the moment
                            Got the cabin roof on now
                            Excuse the sawdust………Not much point in tidying up at the moment
                            Feel very pleased with the roof removal feature……….A nice solution?
                            Edited By Bob Abell on 03/07/2016 14:19:22
                            #66338
                            Ian Gardner
                              @iangardner62867
                              Very good Bob. You found a way of making that whole deck removable- you'll be able to ride in it!
                              All the best,
                              #66341
                                Many thanks Ian
                                Just a stroke of good luck really…….And a nice surprise
                                Now I can get back on the motor drive etc with confidence
                                Ian Gardner
                                  @iangardner62867
                                  She's really going to shift some water and will be a fabulous boat afloat-as long as you don't do your back in getting her in and out!
                                  It takes me back seeing this stage, and Silver Mist was one of my favourite builds- nothing more exciting than seeing a boat take shape, especially a wooden one.
                                  Watching with interest,
                                  #66345
                                    Thanks Ian
                                    You've got me thinking now………The knackered old motor may not be the ideal motor after all?
                                    Might have to borrow a set up out of the VGC?
                                    It's early days still
                                    Ian Gardner
                                      @iangardner62867
                                      Hi Bob,
                                      I didn't mean to cause you to question your decision about a drive motor! I suppose it would be a shame to spoil the ship etc- but that Marlin and big prop look OK and seemed to stir things up when you tested it in the pool. I think Silver Mist is a fairly easily driven hull too. You've got plenty of room to get in there so, as you say, no hurry.
                                      All the best,
                                      #66375
                                        Hello Bob
                                        I get the impression that you are longing to use the Abell Drive in this build and are doing your best to convince yourself that the Marlin isn't up to the task.
                                        How about an engineering challenge!! you could use both setups by fitting the different units on 'quick fit' mountings that would allow for a rapid change over, this would let you compare both setups at the lakeside without having to return to the workshop.
                                        Will Sliver Mist be ready for the Etherow regatta?
                                        Paul …reporting from that well known holiday resort of deaths door.
                                        #66377
                                          Thank you, Ian
                                          Apologies for delay in replying……….Holidays again!
                                          Hello Paul
                                          That`s a good idea, but don`t really fancy disturbing the VGC drive system
                                          Will carry on as planned with the Marlin, for the time being
                                          Not much chance of Silver Mist being ready for the Regatta this month……..There`s far too much to do yet
                                          Only got a couple of weeks left to the show……….Will let you know the exact date
                                            Hi Bob
                                            Glad to see Silver Mist is progressing so well, we should arrange a "2017 sail in" of Vic's Designs when your finished. I'd be keen to travel up from Kent for a get together
                                              That`s a nice idea, Ray
                                              But an even better idea, would be for the Haydock Model Convention to base their yearly competition event on the Vic Smeeds designs, as they did last year, based on Glynn Guest`s models
                                              I wonder who does decide the yearly events for the Haydock show?
                                              Come in…….Larry The Long Build
                                                #66386
                                                  Thank you, Ray
                                                  There must be plenty of Vic`s designs knocking about, just waiting for such an event!
                                                  I like the idea and I can see such a show, taking place?
                                                  It would be a nice get together
                                                    Work in progress for Kevin and Co
                                                    The controls roughly laid out etc……..With apologies for the sawdust!
                                                    Note the Rc is raised well up ( Nice feature ) to avoid any interference and for easy access to the Crystal etc
                                                    Note the fan feature………Querky feature
                                                      Ray,
                                                      I'm very impressed with your +20% Tiddler. A forum member (Phillip Hale was building an enlarged version, unfortunately he hasn't updated us for a while.
                                                      Model aircraft flyers already have a Vic Smeed Memorial Day at Modelair/Old Warden as part of their Festival of Flight on 24-25 September.
                                                      I'm still enjoying watching the progress Bob.
