Hey up!………What`s he doing now?………I hear you ask
Well chaps, I`ve decided to have one motor drive as Vic decreed……Especially, when I`ve found in the junk box, a vintage MFA type 850 motor, one prop shaft and the rudder off Great Eastern…….And it`s a Becker type too
The snag is…….We need a hole up the keel………At this late stage too!
A tricky job, but also an engineering challenge!
First job, is to saw through the keel, up to the hull…….Easy
Next job………..Drill about 8" through the centre of the 8mm keel…….With an 8mm drill!……..Tricky
Problem……..Ain`t got an 8mm drill
Answer……….Make one!………OK Boss
Problem……How do we stop the drill wandering?
Answer………Fit metal guides……OK Boss
And it worked a treat………….More pix to follow
First picture, showing sawn slot through keel
2nd picture………8mm home made tube drill……..Drilled down the centre with 6mm drill, and with teeth filed at the cutting end
Also shows, steel plates, top and bottom………To stop the drill wandering!…………Clever….eh?
Pictures to follow showing inside the hull
Your comments are welcome
