I know where you are coming from Mark.
BUT. Deck access is in three sections, the end two bits I do not envisage having to take up and they will be screwed down. The centre bit will not allow such access as to put weights in, and I will not be able to slide weights forrard or aft from the centre as…. Machinery gets in the way in the middle, and a clever control electronic device….well. not sure where that's going yet !!
The boat is round bilged, and I thought the best way of getting weight as low down at poss was shot/glued in.
I have used virtually all my epoxy resin now but still have loads of fibreglass and an amount of foam. It just calls out to me to build something else with it….?
I am going to resist temptation to build something in parallel, and concentrate on project V. I also need to get an old project (H) going and take the final photos. Those with a memory will have seen it outed in a small photo..
Tomorrow I have to shoot off early so will be down sharp and off by 11 ish. Project S and a lander. project S will be revealed soon…couple of months I believe.
