As it has warmed up considerably and has been raining, the ice will have cleared from the pond allowing unfettered boating tomorrow.
Undecided as to what to take yet.
Work has actually started on Project DW. Wood has been cut and the ply has been found to be a bit less than straight (yes its bent) but the design of the carcase means that this does not matter as sufficient bracing is in place to hold everything square and parallel etc. The Mrs is away this week end so gluing can take place on the kitchen worktop where it is nice and warm and the glue will set. The kitchen worktop is also wonderfully flat and smooth, and indeed my work bench IS a bit of kitchen worktop perched on a workmate.
Before a build I scrape it clean with an old plane blade and then wet`n`dry it so it is flat again with no glue, paint or filler on it. The kitchen top only needs cleaning to remove butter, jam or Marmite of course. sponge and not wet`n`dry!!
I have as stated sufficient bits to equip the craft and how refreshing, I have OOOOOOOdles of space, and the propshaft I happen to have is OK for length and puts the motor roughly central (although this is not a consideration), and a 7.2V speed 600 ECO Graupner will do for the go, but I have various other 540`s, a 12V 600 and some 555`s which of course will be straight swaps if the 600 proves to be not suitable.. I have given NO THOUGHT at all to the rudder access or servo location, or indeed where to put the battery, as this will fit almost anywhere and the thing will need ballast above the weight of the battery in any case.
Heresy?? I should think so!! The NEXT one will be space challenged and I will be getting the micrometer out and all the bits will have to have a set place, but that's likely for the summer.
