  • This topic has 5,251 replies, 84 voices, and was last updated 1 week, 2 days ago by Colin Bishop.
Viewing 2 posts - 5,251 through 5,252 (of 5,252 total)
  • #125947
      Tested the Griffon on Tuesday and both motors were fairly well balanced. It went ok and got up on the plane however this is something i DONT want…it needs to stay flat as speed. I have cut some channels in the base to stop the water bunching up prior to planing, also made much bigger rudders.
      I need to change an esc in the bus I think to even out the starting issue. It still goes alright though….its dead fast.
      Also, a boat which I only thought needed ballasting still has a flooding issue and needs some mods….ho hum.
      The longtail however is now finished and has not only a driver but a passenger as well! Thanks Trev, another charity shop find. Tropical leaves adorn the Battery cover and I now need a couple of polystyrene balls…thought I had some but they may have been thrown.
        Ashley, are those the things which help you to float on your back if you fall into the pond?….
