Viewing 25 posts - 2,376 through 2,400 (of 5,253 total)
  • #81669
      I thought it would be nice to do a paddle steamer so as the most tedious bit would be the paddles I’ve been fettling for a week making a pair,(see album) so now it’s time to make the hull.
      I’m thinking 1830s or there about, lots of deck bits and a big funnel as well as some masts, lovely jubbly!
      Ricky ye pirate 🏴‍☠️
        Won’t be sailing Sunday as it’s mother’s day and I have to whizz down to Hampshire to see ye olde pirate mother!
        Runs in the family I’m afraid 😂
        Ricky ye (not too old) pirate 🏴‍☠️
        #81706
          Seeing mum this afternoon, so free for boating today!
          Fantome, Seahawk and larger lander,
          . I realise it’s only actually 7.30 really but it is a bit grey out….disappointing after all this nice weather. A bit breezy too but this won’t bother the three boats.
            Nippy at pond. Fantome glitching? Too cold to fiddle at pond side. Have stretched out Ariel wire and put a capacitor across the motors. If no good will have to suppress each motor individually, poss ground motors to prop tube. Hasn’t been an issue before?
            Seahawk fast on 9.6 nimh.
            Away next Sunday.
              There's a very good article on motor suppression here **LINK**
              Just click on the link to "Beat RFI"
                The short version is to ensure that the length of wire from the motor terminal to the plates of the capacitor are as short as possible. If there is any wire between the capacitor leg and the motor terminal, there is a transmitting aerial which will let out the interference. The purpose of the capacitor is to shunt the interfering signal away before it gets to the transmitting wire.
                #81717
                  Thanks chaps. Oddly enough I have almost never had an issue with interference. I have in the past bothered with capacitors, but mostly not!
                  I will stick some capacitors between the motor terminals first, as suggested. The ones I have will not quite make it between terminals, hence the one fitted, but I might as well do it properly….so I will lengthen the legs a bit and insulate the wire.
                  It is a bit odd, as the previous esc did not glitch on exactly the same non-suppressed setup, but I have found some esc are more sensitive than others.
                  Project H in for editorial perusal, so with any luck (and assuming the bribe has not been snaffled in the post) ( 10 Bob note) you may see it in x months time and wonder why I bothered, or indeed wonder why you are all not making them as well. How many must have been made I wonder? Did anybody actually make on?  I would not recommend the original power plant however as it was, according to my oversea source, a bit feeble. MB magazine, or at least, part of an article in it was the inspiration, and he knows who he is!
                  Edited By ashley needham on 01/04/2019 15:31:50
                  #81719
                    …and wonder why I bothered, or indeed wonder why you are all not making them as well. How many must have been made I wonder? Did anybody actually make one?
                    Are we talking about Project H's or 10/- notes? You don't half talk in riddles sometimes, Ashley!
                    BTW you might also solder a 0.01uF ceramic disc capacitor from each of the motor terminals to the motor case. Check all the plug/socket connections by wiggling them with the motors running, and give the Tx a good shake at the same time. The type which uses separate cells in a battery compartment have been known to harbour all sorts of gremlins in there. Indeed, any loose or intermittent connections can cause what appears to be radio glitches.
                    Edited By Dave Milbourn on 01/04/2019 16:39:15
                    #81722
                      Project H I was talking about!
                      Will try motor terminal caps first and if that doesn’t do it, try motor case ones. Might have to use the motor mount screws for that as can see difficulty trying to solder on case…they are jolly thick.
                      DM did I appraise you re project H? If not I will mail you.
                      Banjoman
                        @banjoman
                        Ashley,
                        Having experienced trouble soldering capacitor legs to a motor can, I sorted the problem by clamping a copper strip around the end of the can, trapping the capacitor legs between the strip and the can:
                        You can just see the ends of the legs sticking out either side of the large ground wire.
                        I also used this strip to ground the whole set-up to the water via the propeller shaft, as David Harrison says should be done in the article that Dave M. linked to above (cf. bottom of p. 1 and top of p. 2 in the article).
                        Mattias
                        Edited By Banjoman on 02/04/2019 08:21:45
                        #81781
                          Hi all,
                          Sunday sailing was a chilly affair, Noel and the boys arrived about an hour after me with lots of speedy stuff. Nice to see Satan’s leaf blower again, still sounds like a hive of angry bees!
                          I lasted till my knees turned blue and my fingers stopped working, flipping spring ha!
                          On a warmer note, just finished cardboard planking my paddle steamer hull (see album) a few tweaks needed and then it’s smelly fibreglass time.
                          Now a question. I’m thinking of making this steamer around the 1830 era so would the hull have been made of wood or steel plate?
                          Answers on a postcard or just post it here.
                          #81782
                            Almost certainly wood Ricky, maybe with a bit of cast iron worked in possibly. Steel wasn't used until much later.
                              Glad you were all so happy…
                              Nice paddler, great shape on hull Richard.
                              Visited Lowestoft Maritime museum again, fantastic collection of models. Wow.
                                Thanks Colin, that’s what I thought but it’s always good to throw a question out there even if it’s just to exercise the grey cells!
                                Thanks Ashley, I was after almost a clipper shaped bow and it’s turned out as I imagined, so I’m actually quite chuffed.
                                Ricky ye pirate 🏴‍☠️ (fibreglass and more sticky fingers!)
                                #81794
                                Noel
                                  @noel26080
                                  It was quite a good morning on Sunday – the leaf blower was hassle free and just worked. Its useful to find that a tad below half throttle will maintain it on the plane after initial full thrust acceleration, which is very satisfying.
                                  I also took the foam Ekranoplan and put the big 5000mAh 3S into it. This suited it a treat, giving a long run time, and ballast enough to allow a bit of air to get under the wings, but not actually enough to cause a nose up and flip. It was terrific.The skeg could do with replacing with a rudder because the turning circle is still impractical though.
                                  #81851
                                    Hi all Bushy boaters,
                                    Just a heads up, it’s the Chestnut parade on Sunday so parking might be more of an issue than usual, also the car parks will be shut from 12.15 till 1.30 so if your late leaving you might not be able to!
                                    Looks like a no go Sunday.
                                    #81853
                                      Ricky. Good point. We have found in the past that parking has been ok, but as you say we have to sharp off. I have to be sharp off in any case as have a blow in Byfleet in the afternoon wi` `t brass band, aye. Ashley
                                      #81862
                                        Won’t be there myself, got a bike club ride to Hastings.
                                        Am planning a morning next week as the weathers going to warm up a bit, will post what day.
                                        catch you later.
                                        #81886
                                          No probs parking as chestnut Sunday is on 14th MAY….
                                          Chilly to start.
                                          Manchester going well on 14.4V and new ESC working ok. Did a slow pass and saw port prop was stationary…investigated, tightened up coupling grub screw and…..Woah!!! How fast!!! Megga.fast. Fastest its ever been, although OBVIOUSLY I drive it at a scale speed all the time/mostly/sometimes/hardly-at-all. Didn't try anything else out.
                                          Trevor had the demonic all-singing all squirting/noisy/flashing ex-police fireboat out, and what fun.
                                            Sorry Ashley, saw the sign in the park and thought it was this Sunday, Doh!!
                                            Ricky the shortsighted pirate 🏴‍☠️!
                                            #81894
                                              Will be pondside tomorrow,Tuesday, arriving at about 9.30 – 10.00 ish. Would be nice to have some company if just to stop me talking to the ducks!
                                              #81896
                                                See you there. Will have the London if nice for a few snaps. Ashley
                                                #81898
                                                  Nice low wind speed should be nice for square riggers!
                                                  #81952
                                                    Great morning boating last tues with Richard and Peter.
                                                    Unfortunately the sun went in and although warm it was slightly overcast so no snaps were taken. The gear refused to fire up on the London at first but after taking out and then re-plugging in the leads to the rx all was ok.
                                                    Tomorrow I will `ave the Manchester, Shorty and Ferry. Possibly summat else if I get a spur of the moment whim, but I will have a car full already. Bound to be busy at the park as it will be a nice day so I shall be there sharp to get a parking spot.
                                                    As an aside, some of us will be attending the Kempton steam museum Stationary engine and model boat show on I think Sunday the 19th May. Richard is finding out more info, like if we can troll up and sail or have a table to display our MAGNIFICENT boats on, or wot.
                                                    Edited By ashley needham on 20/04/2019 18:04:40
                                                    #81954
                                                      The chap I know who is organising the Kempton do has been on holiday this week so will track him down after Easter.
                                                      Will see you bright and early tomorrow!
