Lovely day today, bit breezy at the pond. Weed large p[atch far side about halfway out.
Firstly. Hovervan. Had a bit of a faff (thats the air coming out from underneath) on the main pond then portee`d it over to teh stream to try it out on weed…it being easy to recover in the event of a stuck situation. Pleased to say that it coped admirably with several large clumps when in hovering mode..weed over which it got stuck on without the lift motor.
Rescue LCM out as well as the Sunderland and BFB3. Mick the sail had his latest creation out for its first spin, an Invincible class battleship circa 1893. A semi ket from someone or other who he was not impressed with….fittings the issue, half were very good, the rest rubbish. Hull and other stuff (barring the string supplied for rigging I recall) very nice. Looked glorious and sailed a trest,. Such great colours,,,,white/buff superstructure and that cheeky little white boot-topping.
5 other boaters down, one succumbing to weed…along then with the lcm although that just limped back. happily the strong wind soon blew the affected boat back into shore.
This has inspired me to make a paddler…not the Victorian warship envisaged (at leasst, not yet) but a Victori8an Nile gunboat, loosley modelled on the "El fateh" yes really, look it up.
Built at Wivenhoe Shipyard in 1896 by Forrestt & Co. Ltd., together with 2 sister ships for the Kitchener Nile expedition against the forces of the Mahdi in the Sudan . With her sisters, 'El Fateh' was built in sections of steel and fitted with water tight bulkheads. Shipped to Alexandria in sections, the ships were transported up the Nile to Assouan where they were reassembled for action. 'EL FATEH' was commanded on the Nile by Lt. David Beatty R.N. later better known as Admiral Earl Beatty, commander of the Battle Cruisers at the Battle of Jutland.
It is a sternwheel boat, and while we wwere discussing paddles and weed I had a sudden inspiration, and decided to try a four bladed rear wheel…the idea being there would only be one blade in the water at any one time and so it would be less likjely to pick up weed, rather than having loads nof blades splashing about.
I realise this wont be efficient but thats not the point of it. I can always make another wheel to fit during weed free months, assuming the boat looks reasonable. I am not spending much time on it. It will be populated with circa Kitchener era soldiers in 54mm size from my collection to add interest. have started already..will use a 20mm thick ply base to effect a no (or very little) draught design, AND I just happen to have an MFA 2.5:1 geared 540 motor just the job for this. Only need some sort of drive now, thinking of plastic chain and sprockets??
