Ardunio Sketch by Roy Cheers
The Arduino sketch in support of Roy Cheers ‘An Introduction to Arduino’ article as published in the May 2020 Edition of Model Boats Magazine. (See Page 59)
//   Demonstration of propulsion & thruster control
// SECTION 1 ...............................................................................
#include (NB this line should have Servo.h7 added between less than and greater than sign characters which do not reproduce on the text editor used on this document.)
// Assign names and pin numbers for input from radio receiver
#define Speed_In_Pin 4         // Channel 3 throttle
#define Rudder_In_Pin 2       // Channel 1, rudder and stern thruster
#define Ch2_In_Pin 3           // Channel 2, bow thruster
Servo port_ESC;     //create a servo object to control the port ESC
Servo stbd_ESC;     //create a servo ojbect to contorl the stbd ESC
Servo Steer;        //create a servo object to move rudder
// Define pulse durations corresponding to neutral positions
const int SpeedNeutral = 1500;        // Value in mu of Neutral/Zero speed signal from receiver
const int RudderNeutral = 1500;
const int Ch2Neutral = 1500;
const int BowThrustDirPin = 11;       //Define pins for outputs to devices
const int SternThrustDirPin = 12;
const int ThrusterPwrPin = 13;
const int ThrustDisable = 200;       // Plus/minus change from throttle neutral over which thrusters
                                     // are enabled.e.g if = 200, throttle signal must be between
                                     // 1300 and 1700 for thrusters to be enabled, if neutral = 1500.
                                     // Confirm and adjust as necessary.
const int RudderLimit = 300;         //Change of rudder input from neutral below which thrusters are off
                                     //i.e. only turned on when a tight turn is signalled
                                     //change value to suit
boolean ThrPwrEnabled;               //Is TRUE if thruster operation allowed.
boolean ThrusterPwrOn;               //Is TRUE if thruster power is actually on
boolean DirnChg;                     //TRUE if a change in direction of the thrusters is to be made
String BowPush, SternPush;           //Is "Right" if model to be pushed to the right, othewise "left"
int Mvrg_Mode;                       //Manoeuvring mode: 0 normal, 1 side thrust, 2 rotate
int SpeedInput, RudderInput, Ch2Input;      // Values read from rc receiver
int SpdMove;                        //Amount speed signal has changed from neutral
int R, S;                           //temporary variables
// SECTION 2 ........................................................................
void setup()
  Serial.begin(9600);                 //This is required for any test values you wish to display.
  pinMode(BowThrustDirPin, OUTPUT);       //Define pins being used for output.
  pinMode(SternThrustDirPin, OUTPUT);
  pinMode(ThrusterPwrPin, OUTPUT);
  digitalWrite(BowThrustDirPin, LOW);     //Set relays unpowered
  digitalWrite(SternThrustDirPin, LOW);
  digitalWrite(ThrusterPwrPin, LOW);     // Set thrusters off
  ThrPwrEnabled = false;             //Set conditions off for thruster power
  // attach servo objects to their signal pins, these will generate the correct
  // pulses for driving Electronic speed controllers, & servos
  // designed to interface directly with RC Receivers
  port_ESC.attach(9, 1000, 2000);  //attach these pins for output to ESC's
  stbd_ESC.attach(10, 1000, 2000);
  Steer.attach(6, 1000, 2200);     //attach this pin for output to rudder servo
}    // End of 'setup'.
//SECTION 3..................................................................................
void loop()
// Read signals from RC receiver; start timing pulse when voltage goes high
  SpeedInput = pulseIn(Speed_In_Pin, HIGH);
  RudderInput = pulseIn(Rudder_In_Pin, HIGH);
  Ch2Input = pulseIn(Ch2_In_Pin, HIGH);
//If you want to verify the pulse durations that your receiver is sending to Arduino,
//remove the comment slashes from the code below and, with your Arduino connected to your
//computer, and your Arduino sketch open, click on 'Tools -> Serial Monitor'.
//Do not touch the control sticks on your radio and observe the readings. Ajust your trim tabs
//if you want to change the values you see.
//Then move the sticks to confirm the direction that the pulses increase.
//Remove the comment slashes from the following seven lines.
//Serial.println("Throttle    Channel 2      Rudder");
//Serial.print(SpeedInput);
//Serial.print("        ");
//Serial.print(Ch2Input);
//Serial.println(RudderInput);
//delay(500);                                              //slow down execution to give time to read
//If any channel signals increase in the wrong direction, use whichever of the following statements
// apply to reverse them, by removing the '//'
//  SpeedInput = 2 * SpeedNeutral - SpeedInput;
//  RudderInput = 2 * RudderNeutral - SpeedInput;
//  Ch2Input = 2 * Ch2Neutral - Ch2Input;
//If there is no throttle signal, or an out-of-range signal, set zero speed
  if ((SpeedInput < 900) or (SpeedInput > 2100))
    SpeedInput = SpeedNeutral;
// Determine manoeuvring mode; assume normal control then check to see if stick positions
// match other modes. Also assume that received signal may vary from neutral by +/-50 mu,
// with no stick movement, due to radio interference, etc.
  Mvrg_Mode = 0;
  if (abs(SpeedInput - SpeedNeutral) < 50)           // Throttle stick in neutral
      if (abs(RudderInput - RudderNeutral) > 50)     // Rudder stick not neutral
          Mvrg_Mode = 1;                //Side thrust
      else if (abs(Ch2Input - Ch2Neutral) > 50)     // Ch 2 stick not in neutral
          Mvrg_Mode = 2;                //Rotate
// SECTION 4...........................................................................
//Assume thruster power can be switched on; but is set off if in normal control
//and either of the following apply
// Forward/astern speed is high enough that thrusters ineffective
// Turn is not tight enough to require thruster assistance
  ThrPwrEnabled = true;
  SpdMove = abs(SpeedInput - SpeedNeutral);
  if ( Mvrg_Mode == 0 )
      if (SpdMove > ThrustDisable || abs(RudderInput - RudderNeutral) < RudderLimit)
  if (ThrPwrEnabled)
      if (Mvrg_Mode == 1)                                   // Sideways movement
         if (RudderInput > RudderNeutral)                    //Rudder stick to right; side thrust right
            BowPush = "Right";
            SternPush = "Right";
          else                                               // Rudder stick to left; side thrust left
            BowPush = "Left";
            SternPush = "Left";
      else if (Mvrg_Mode == 2 )                              // Rotate
         if (Ch2Input > Ch2Neutral)                          //Rudder stick pushed forwards; rotate CCW
             BowPush = "Left";
         else                                                //Rudder stick pulled back; rotate CW
             BowPush = "Right";
             SternPush = "Left";
      else   // Must be Mvrg_Mode 0
         if (SpeedInput - SpeedNeutral > 0) {S = +1 ;} else { S = -1;}
         if (RudderInput - RudderNeutral > 0) {R = +1;} else { R = -1;}
         if (S * R > 0 )                                 // Ahead - Turning right; Astern - turning left
             BowPush = "Right";
             SternPush = "Left";
         else                                            // Ahead - turning left; astern - turning right
            BowPush = "Left";
// SECTION 5 ................................................................................
   DirnChg = false;
   if (digitalRead(SternThrustDirPin) == LOW && SternPush == "Left")  //These represent opposite directions
       DirnChg = true;
   else if (digitalRead(SternThrustDirPin) == HIGH && SternPush == "Right")   //also opposite
       DirnChg = true;
    if (digitalRead(BowThrustDirPin) == LOW && BowPush == "Left")    //Also opposite directions
       DirnChg = true;
    else if (digitalRead(BowThrustDirPin) == HIGH && BowPush == "Right")      //also opposite
       DirnChg = true;
   if (DirnChg == true || ThrusterPwrOn == false)      //If direction change reqd OR thruster power off
       if (ThrusterPwrOn == true)
           digitalWrite(ThrusterPwrPin, LOW);           //Switch off power to thrusters
           delay(10);                                  //Pause 10ms for kickback voltage to dissipate
        if (BowPush == "Right")
           digitalWrite(BowThrustDirPin, LOW);      //Bow Thruster pushes model right
        else
            digitalWrite(BowThrustDirPin, HIGH);    //Bow Thruster pushes model left
       if (SternPush == "Right")
           digitalWrite(SternThrustDirPin, LOW);           //Stern Thruster pushes model right
       else
           digitalWrite(SternThrustDirPin, HIGH);           //Stern Thruster pushes model left
        digitalWrite(ThrusterPwrPin, HIGH);             //Switch on power to thrusters
        ThrusterPwrOn = true;
     else
         digitalWrite(ThrusterPwrPin, LOW);                // Thrusters off
         ThrusterPwrOn = false;
//Removing the comment slashes from the following lines will display the information.
//You may find this useful for testing, or just to check what's going on.
//Serial.println("Man'vrg Mode     Thr Pwr?         Bow      Stern       Rudder Inp");
//Serial.print(Mvrg_Mode);
//if (ThrPwrEnabled) {Serial.print("ON            ");} else {Serial.print("off             ");}
//Serial.print(BowPush);
//Serial.print(SternPush);
//Serial.println();
//delay(400);
  if (Mvrg_Mode == 0)
     port_ESC.writeMicroseconds(SpeedInput);            //send signal to ESC's
     stbd_ESC.writeMicroseconds(SpeedInput);
     Steer.writeMicroseconds(RudderInput);              // send signal to rudder servo
}     //End of 'loop'
