Vic Smeed’s Silver Mist
  • This topic has 842 replies, 5 voices, and was last updated 1 day, 1 hour ago by Colin Bishop.
Viewing 25 posts - 151 through 175 (of 843 total)
  • #64792
      Work in progress picture………For G.I.A.
      Have fitted a couple of formers in the stern to control the 4mm planking
      And checking the general shape before planking starts in earnest
        Hi Bob
        Progress looks good, have you thought about the rudder position ? you may have an location & access problem if you want your tiller/quadrant below the deck.
          Thank you, Ray, for your timely cautionary advice
          Don't think there's a problem……All the top wood will be removed after planking and I can then drill down or up?
            Clamping tapered planks at the prow is normally a tricky job
            This time I`ve decided to make a device………Fit for purpose!
            It`s a bit OTT I know, but I think I`ve cracked it?
            #64827
              220416 461.jpg220416 460.jpg220416 459.jpgHi Bob
              Some photos of SM stern bits maybe some help, the mahogany brightwork from Mantua Models 1.5mm sheet, the Caldercraft stancions are the most expensive part of the boat. 13amp plug pin my favourite type of tiller arm
              #64828
                Thank you, Ray
                Nicely built
                The warm colours look nice too
                Are you building anything at the moment?
                  Hi Bob
                  Yes always building something, currently building MTB 71 at 1/24th scale which I first saw afloat 20 years ago at Portsmouth and one of the guys there gave my a copy of the Vospers drawing, now she is at Duxford in preservation. First time I've fitted transom hung double rudders, I hope they work well with the twin screws. I allegedly build for my Grandsons but really for me
                  #64832
                    Nice build Ray
                    What about the rest of it?
                    Looks a nice quality build too
                    BTW……..Saw one of your Vic Smeed model aero`s on the net, the other day
                    It was a high wing cabin model
                    #64836
                      Thanks Bob
                      I enjoy a bit of variety, photos of some of my other projects in my album. Starting a scratch built HMS Belfast in the autumn, but I recall saying that last year ! I have kits for Tony Nijhuis electric Vulcan & Ducted fan Hawk waiting for some attention, Fairly keen on model sailing barge racing with AMBO boys at the moment and need to mould a GRP wing keel for my Veronica to make her go faster, so plenty to do Yes I enlarged Vic's Mamsell to 52" span and had it published in RCM&E 2003 it was originally a free plan in Aeromodeller in 1955 the year was born.
                        WIP for GIA, and PT…….Both of you…….Get well soon
                        Had an all day wrestle sorting out the 1st pair of planks…….It may look a pain in the butt, but I find it quite interesting sorting out the tricky areas……..Believe it or not?
                        As you can see……You can`t have too many clamps on a job like this
                        The Heath Robinson prow clamp has saved the day and is much admired by a few of our forum members
                        Progress will be rather slow from now on……..Waiting for the glue to dry
                        #64866
                          four planks.jpgManaged to get four planks on today, chaps
                          In fact, at half time during the Man United v Everton match. I dashed upstairs, did the biz with plank number 4 and came down again, just in time for the start of the 2nd half!
                            Work in progress report
                            Finding it a bit awkward now, planking this way up, so it`s time to turn over for better access
                            Planking with 4mm wood is having it`s challenges, it doesn`t like the tail end bend
                            #64909
                            IAN_I
                              @ian_i
                              Hi Bob..
                              ​planking looking good, have you been soaking or steaming the planks to bend?
                              best regards
                              #64913
                                Hello Ian
                                I don`t soak or steam planks these days
                                I get away with it, because the wood is so green these days from the local wood shop
                                I went for a few more planks today……And some of the wood felt wet through, as though the roof was leaking!
                                  That`s better………"Let the dog see the rabbit!"……….( Old Northern term )
                                  It`s nice having the clamps handy, when planking up
                                  I`ve found the Workmate very handy for the build
                                  Note the 12" rule for size comparison
                                  #64924
                                    I`m pleased that the Vee Clamp can still be used
                                    Got two planks under minor flex over night
                                    Might give a splash, for good measure
                                    #64927
                                      Hi Bob
                                      This stage is really the best part of boat building seeing the hull developing you may consider some doublers both sides of the rear keel worth while to increase your plank gluing area ? What adhesive are you using ? I'm a convert to Gorilla glue.
                                        Hello Ray
                                        Do you mean the rear curved edge of the keel?
                                        It could be a problem area, when fully planked……..Hence, no access for sealing?
                                        Will take that on board……..Thanks for your comments
                                        It will also beef up the rudder tube area too
                                        Edited By Bob Abell on 26/04/2016 08:55:35
                                        #64930
                                          Hi Bob
                                          Yes I'd still be thinking block hollowed out for that rear section to achieve some nice compound curves as Vic' little original, or saw cuts across th back your planks to help them go round the bend a little easier.
                                            Hark at me!
                                            Forgot, we are having twin props, so the keel won't need the rudder hole drilling after all!
                                            Thinking of having one 850 motor with timing belt drives to the twin props
                                            Should look interesting?……I like to see belt drives and pulley's whizzing about
                                              Just another work in progress picture
                                              Due to lack of clamps and trickiness at each Pointy McPointy end, we can only handle one Plank McPlank at a time now……….That was a bit silly, but bang up to date!
                                              The rear plank is being finally glued in position and the near plank is wetted (Thanks Ian) for bending overnight
                                              This wetting method really does work
                                              #65014
                                              Peter Fitness
                                                @peterfitness34857
                                                You do like those big models Bob, your back must be in good shapesmiley
                                                I like the planking jig arrangement, and the Workmate is extremely useful. I use mine all the time and it's looking nearly as worn as I do.laugh
                                                Peter.
                                                #65015
                                                  Thank you, Peter
                                                  It's nice hearing from you again
                                                  The jig was a good idea at the time, but I've resorted to one plank at a time now, so that I can get a grip on the extreme ends of the planks to maintain the tight curve
                                                  ie…..The ends now overlap at the points
                                                  Kind regards
                                                    Just for you Peter in Oz
                                                    We've got snow this morning!
                                                    No good for PVA!
                                                      Hi Bob
                                                      Not only snow but you also travelled back to the monochrome 1950s
