Hi Arthur,
Your model of Amsterdam/Malabar looks very neat and tidy. Are you going to complete it in a pristine paint finish or is it going to be weathered to some degree? I think I will finish Shemarah looking slightly scruffy but not as bad as some of the photos I have seen of her. However now she is operating as an offshore industry support vessel she always seems to look immaculate.
Over the last couple of months I have been distracted by work and various DIY jobs at home. I have finally got around to fitting a dust extractor in the workshop so we will be able to use the disc sander and scroll saw without covering everything in dust and starting coughing fits.
Shemarah has emerged from under the covers, blinking in the sunlight again. I have abandoned the winches for a while and made a start on the deck platform around them. I started by making a paper pattern to make sure the platform will fit around the winch bases as they are not fitted exactly where shown on the plans.
The supporting structure has been built on a drawing of the platform, which is a combination of the photos I have of the area and the plans. Most of the structure is 2.5 mm angle or Tee section plastic, fixed together with superglue. There are a couple of 2 mm thick 6 mm wide strips along and across the base into which are fitted 4 brass pins to locate the structure on the deck. Here is an early stage of the construction.
After carefully prising the base off the paper pattern it has been sprayed in grey primer ready for fitting the grating.
There are about 70 separate pieces of plastic strip making up the framework. The grating will be made in two halves from Isopon aluminium mesh. The mesh will be sprayed gun metal grey and given a bit of scuffing and rusting to make it look as though it has been there a while.
I will post a photo of the completed assembly in a few days. This Saturday is our club's first show outing of the year with the traditional Goole Hobbies exhibition where we will be attempting to win the coveted Lord Mayors trophy for the best stand. (only one sucessful year in 18 attempts) Last year I had my 15 minutes of fame and was interviewed on Vixen FM radio with questions about the hobby and Goole Model Boat Club. Not quite up to Bob Abell's celebrity status but its a start.
Gareth
Edited By Gareth Jones on 28/02/2013 20:29:47
