Hi Garath,
Thank you for reply , my winch is mostly styrene , odd bits of tube , discs cut from styrene,
for drums , centures old biro tubes centure drive out of cheap plastic toys ,
brake rods striped copper wire stiffend using power drill, brake wheels press studs ,
cable builders line , paints acrylic from a shop called THE WORD onlly £3 a box ,
rust is a bit of assorted mix plus a bit of dry brushing ,…..a bit of artistic licence i did attend a art school when a boy ……..when the model is at the complete stage all finishes will get coat of semi matt to make weather proof , thank for info on drive , looking to use it on my paddler…….Larry..
