Puffer advice
Puffer advice
Home Forums All things floating Puffer advice
Viewing 25 posts - 1 through 25 (of 97 total)
  • #120336
    Alasdair Allan
      @alasdairallan37423
      Hi I am toying with building a model puffer, and would welcome views on the best options. Orion Mouldings sell two similar sized fibre glass hulls, one with rivets and the other without. The one without the rivets looks v nice but is cheaper than the one without. This makes me wonder is there something about the one with less detail that is stronger/ better? Have not completely ruled getting a kit, but quite fancy the idea of building from scratch into a fibre glass hull.
      Len Morris 2
        @lenmorris2
        Hi Alasdair,
        I’m sure both hulls will be strong enough.  The final strength really comes from the bulkheads and stringers you fit inside.
        Puffers look good with plate and rivet detail.  It can easily be removed on a fibre glass hull with excessive sanding.  It can also be easily repaired, or added to a smooth hull.
        It might depend on the hull finish you choose.  Puffers were normally a bit scruffy.
        Len
        #120339
          Alasdair, I suspect the difference in cost is nothing more than a reflection on the additional time that goes into the mould preparation for the riveted version.  I doubt there is any difference in strength as a fibre glass hull is a relatively sturdy construction to start with and the rivet detail does not add to that strength.
          Kits possibly make life a little bit easier for having all the detail bits and pieces supplied for you but, if you prefer to do more yourself you could either buy after market details, or even scratch build them.  It depends on how much time you have available to build and how accurate you want the detailing to be.
          Puffers are certainly well known for have particularly well used hulls so there is plenty of scope for rivet and plate detailing as well as weathering.
          #120365
          Alasdair Allan
            @alasdairallan37423
            Many thanks – I think getting the Caldercfraft kit is probably going to be as cost and time effective, in the end, as getting a hull and building up, as the kit has a lot of detail. I agree, Len, about puffers being scruffy, so you may eventually see me seeking advice on weathering paint! In the meatime, if there are puffer experts out there, I would welcome both technical advice and also comments about which puffer the Northlight most resembles.  There was a Warlight and a Sealight but not sure if there was ever a Northlight. She looks like one of the puffers built around the time of WW1. Thanks
            #120369
            Len Morris 2
              @lenmorris2
              Hi Alasdair,
              Have a look at David Hayman’s one hour BBC documentary about Clyde Puffers.
              It’s easy to find on You-tube.  I think you’ll find yourself going back to it several times for reference and it provides no end of other leads.
              Len
              #120389
                Alasdair, this month’s Model Boats Magazine ( June ’24) has a build article in it of a Windermere steam barge, The SS Raven, that uses the Orion Mouldings Clyde Puffer fibreglass hull as a basis.  I’m sure you’ll find it an interesting read.
                #120397
                Alasdair Allan
                  @alasdairallan37423
                  Thanks Richard – yes so I see – this looks v interesting. I am new with propellors (as opposed to paddles) so will doubtless be back for further advice!
                  #120438
                  Alasdair Allan
                    @alasdairallan37423
                    would there be a model boats article somewhere in the archives about building the Northlight? I have heard a rumour to that efect, but not sure!
                    #120442
                    mmcp42
                      @mmcp42
                      hello Alisdair
                      I’m building a Puffer based on the full set of articles for Clochlight, together with plans published in 1980/81
                      cheers
                      Mike
                      #120445
                      Alasdair Allan
                        @alasdairallan37423
                        Thanks for that Mike – do you know where I would find the artices for Clochlight (what numbers of the magazine were they in?) .  Was the Clochlight a scratch build? thanks Alasdair
                        #120446
                        Alasdair Allan
                          @alasdairallan37423
                          One thing I do notice about the Northlight model is that the fore deck doesn’t camber up to the bow but is completely horizontal all the way forward. Pretty sure all the puffer decks (except possibly some of the very early canal ones) sloped up at for’d end, so may try to change that.  Am going for a day trip on Vic 32 soon, so will gather evidence!
                          #120447
                            Alasdair, that is a perfect example of how kits can frequently be simplified for the sake of keeping the cost down as well as making the model that bit easier to build.  These are just the sort of things you need to identify when building a kit and then make the conscious decision whether to build the kit in its simpler form or deviate from it and make yours more realistic.  Frequently balanced against this are the two main considerations of A) Whether any other observer will notice the difference and care and B) Whether you can live with the simplified version or whether it will bug you for the rest of your life!
                            As an example I’ve just finished my Ben Ain kit, shown here:
                            Ben Ain
                            The aft accommodation was supplied as a fibre glass moulding.  All the examples I’ve seen of this built model have used this part and it makes into a perfectly acceptable model.  A bit of research though makes you realise that the top has no camber, the plate joints in the sides are perpendicular to the top of the moulding when they should be vertical and one or two other niggly bits.  The decision was to either use the kit supplied part and crack on with the model or spend the next couple of weeks building a completely scratch built bespoke item from wood.  Not an easy decision!  But you have to be happy with the end result so only you can make the decision.
                            Congratulations though for identifying the issue and realising you have identified a compromise.
                            #120449
                            mmcp42
                              @mmcp42
                              hello Alasdair
                              the articles were in Model Boats May1980 and ran for 12 issues
                              I can scan the articles if you need
                              cheers
                              Mike
                              #120467
                              Alasdair Allan
                                @alasdairallan37423
                                thanks Mike – that would be very kind of you.  Alasdair
                                #120468
                                Alasdair Allan
                                  @alasdairallan37423
                                  Have taken the plunge and will buy the Caldercraft puffer (have coveted people who own them for many years).
                                  A few daft questions, as someone who is a novice with propellors rather than paddles, so apologies for taking advantage here of people’s patience!
                                  – looking at smoke units I think I have a fair idea what will fit, but was not sure if people had views on the BluX smoke units. They use “water based fluid” and look v effective, but is very unclear to me from adverts whether they have a heat / burning element or are nebulisers.  Would prefer to stick to the latter for safety reasons.
                                  – Does prop shaft have to be angled to keep the inboard end of it above waterline? I know somepeople do this to guarantee waterproofing, but it looks inaccurate (and probably impractical) to do this in a puffer. Many people seem to have models that quite happily have prop shafts running along the keel.
                                  – can people recommend a good motor and prof shaft for this? The kit in question is the Caldercraft Northlight.
                                  Again, thanks to everyone for your help!
                                  #120469
                                  mmcp42
                                    @mmcp42
                                    hello Alasdair
                                    I’m out at Shuttleworth today
                                    will be on the case tomorrow
                                    cheers
                                    Mike
                                    #120471
                                    Alasdair Allan
                                      @alasdairallan37423
                                      Many thanks again Mike
                                      #120472
                                        Alasdair, Interesting the BluX smoke unit.  I have seen them before but didn’t follow up mainly as they are in Australia but, now you mention it, I’ve tried to find a bit more on them.  I agree it is not very clear how they work.  They are described as “water based” but you have to use a special fluid, rather than tap water.  They do use a wick and they do involve heat so I suspect it might be some kind of heating element that is heating a water based emulsion.  So it will share some of the downsides with the old oil heater types, i.e. using a higher current and generating heat, but it will be a lot safer than them as you are not using neat oil.  It does seem to produce a good quantity of smoke.  It may not be as good as the nebuliser types at following engine speed and obviously won’t be as convenient as simply putting some more water down the funnel to top it up.
                                        I’ve done a couple of reviews recently of a UK produced smoke generator of the nebuliser type which you might want to consider as well.  I was going to send you a link to his web site but it is down at the moment for refurbishment.  This is his YouTube page though where his products are demonstrated:
                                        Denes Designs
                                        Prop shaft inboard ends can be lower than the water line however you must be aware then of the need to ensure the shaft is better sealed.  Bushes need to be a good fit on the shaft, sealed ball bearings are better, and thrust arrangements need to have the minimum clearance.  If I had to have an inboard end lower than the water line I would use sealed ball bearings rather than bushes, but that’s just me being over cautious. When I built the Ben Ain this was my first attempt:
                                        fc05vr1jshdykh4yrdbqu25vyrvrlg3y
                                        g1nuiyuk5ytuks0doumiyoqm8qqer65z
                                        But I didn’t like it after tests in the bath so I ripped it all out again and fitted a sealed ball bearing shaft arrangement.
                                        Have a chat with Prop Shop for shaft and propeller suggestions or JoTiKa, who supply Caldercraft kits.
                                        #120474
                                        Alasdair Allan
                                          @alasdairallan37423
                                          Many thanks – that is very helpful.  I think i will go with sealed ball bearing shaft and will take up your advice re speaking to the others you mention.
                                          #120481
                                          Len Morris 2
                                            @lenmorris2
                                            Alasdair,
                                            Have a look at the prop shafts used on model submarines (it’s a bit hard to keep the inboard end above the water line!).  I think the most common are the Dutch Raboesch water proof type.  Expensive but good insurance.
                                            P1050511
                                            Note the instructions tell you how to shorten the shafts to suit your model exactly.
                                            Len.
                                            #120540
                                            mmcp42
                                              @mmcp42
                                              hello Alasdair
                                              all scanned
                                              if you can get your email address to me I can zip them up in batches and send them over
                                              cheers
                                              Mike
                                              #120725
                                              Alasdair Allan
                                                @alasdairallan37423
                                                Hi again Richard,
                                                Thanks for help, as ever.
                                                You might need to explain a wee bit to me what you mean by “thrust arrangements need to have the minimum clearance”. Apologies for being slow on the uptake! I have bought the Caldercraft Northlight and, after some research, will call her the Druid. It will be awhile before I get properly started on her though, so I will start looking for components etc.
                                                #120728
                                                  Hi Alasdair, you should have some means of taking the thrust from the propeller and transmitting it to the stern tube.  This could be a brass washer or it could be the flange on the end of the stern tube bush.  Either way, at the back end of the tube you want to transmit the thrust from the propeller into the stern tube to push the boat forwards and, inside the boat at the forward end, you want a similar arrangement to transmit the astern thrust from the propeller into the forward face of the stern tube.
                                                  If you do not allow a very small clearance, longitudinally, between these two thrust arrangements there is always a slight risk that the shaft could become tight in the tube.  You want this clearance small enough to allow the shaft to move backwards and forwards freely between its ahead and astern positions but, particularly when the inboard end of the tube is below the water line, you want this clearance to be as small as possible to try to minimise seepage of water into the model as it passes the inboard bush.
                                                  Does that make a bit more sense?
                                                  #120730
                                                    Alasdair,
                                                    This subject has just been covered comprehensively in the current (June 2024) issue of the magazine by Glynn Guest in his Drivelines article. The article is basically a repeat of the original in the 2011 Special Issue edited by myself and you can see this in the  Features section of the Forum here:
                                                    Drivelines
                                                    Please note the the diagrams are all at the end of the feature article due to the conversion process from MyTime Media to Mortons forums.
                                                    Lindsey agreed to the updated article as the subject matter crops up very frequently in questions on this and other forums.
                                                    Len Morris 2
                                                      @lenmorris2
                                                      Alasdair,
                                                      What ever drive line arrangement you choose, it is good to have some initial adjustment on the motor/motor mount, even if it’s just paper shims.  After its all in place run the motor and measure the amps it draws with a multimeter.  For the best alignment with your chosen layout you are looking for the lowest amp reading.  If you lock the motor in that position you can’t do much better.
                                                      Len
