Fitting out hull
I.e. props shafts
mick27/10/2007 21:58:00
127 forum posts
74 photos
i have a 42"+12" hull i have two decoperms spare and was going to put these in
but could do with some advise with length of shafts +how big the rudders should be was
also going to put in two 6v 4amp hr batterys in  but would i get enough running time ?
i also wondered what props to use and was going to put two bobs boards in to keep costs
down what rateing should i use  well hope you lads can help tryig to keep cost down as being on a fixed income thanks for your time
Jake Knight22/02/2008 20:59:00
90 forum posts
24 photos
hi mick
as you said your boat is 42"+12" but what typre of boat is it?
if its a slow boat and the motors have to push along a lot of weight a bigger battery may be needed
but i have used 6v 4amp on some of my boats and it gives a very long running time of up to 1 hour
Len Ochiltree23/02/2008 12:56:00
525 forum posts
64 photos
Hi Mick,
As a rule I try to keep my motors above the water line,others keep their prop shafts horizontal,have a trial run to see where all the electric stuff will fit ,then you can work out how long and where motor and prop can go.
Len
mick23/02/2008 17:48:00
127 forum posts
74 photos
to jake knight i have changed tack on twin shafts decided to put a 12v motor in
i am useing mfa 850 with a water cooling coil on and a 12v 7amp hr battery
and a 55 twin bladed prop with an electonize 15amp esc do you think this should
be ok look on my photos its the boat i was trying to find the name of i have decided
to modify it to look like a chris craft boat thanks for the input mick
Paul T23/02/2008 20:02:00
7231 forum posts
1226 photos
2 articles
Hi Mick
I would advise caution before fitting the esc it would be best to check how many amps the motor pulls under full load, to do this fit the motor / prop shaft / prop in the hull and put it in a bath full of water connect an amp meter to the loop and fire up the motor this will give you the maximum amp load.
mick23/02/2008 20:36:00
127 forum posts
74 photos
hiya paul
the amp load that mfa say is supposed  to pull 11amp max  but i will check just i case
thanks for mentioning  it  never thought about  that  i was just  going  what was stated thanks
mick
Paul T24/02/2008 20:16:00
7231 forum posts
1226 photos
2 articles
Hi Mick
The size of prop and the tightness of the prop shaft all add to the amp draw you might be surprised at just how many amps the initial pull will be.
mick24/02/2008 20:39:00
127 forum posts
74 photos
hiya paul  you made me think and i have mfa mechanical controller i might  use
that instead dont wont to blow the esc although  it is fused at 15 amps  thanks
again mick
Tony Green Steam
Restorers Wanted
Shrek
