motors
us custom boat
Hugh Connolly15/12/2008 14:50:00
48 forum posts
65 photos
hi looking for help,my daughter brought me a ready to go r/c american custom boat when she was in usa ,but when i took it to our local model club pond it would not work when other boats in pond.so last week took deck of and stripped all elec,out going to put speed controller and other elec  in,my problem is the boat has in rudder it had two motors for steering i am putting in two new motors,how do i get motors to control steering, thanks
60watt15/12/2008 15:40:00
253 forum posts
14 photos
Do you mean "no rudder" or in-board ?
My transmitters allow me to unscrew and rotate the sticks by 90 degrees.
Some transmitters can "mix" a throttle and rudder signal for the purposes of V-tail aircraft.
You can get a device to fit between receiver and servos and another speed controller or drive two motors with one controller and fit a rudder.
Tom
Hugh Connolly15/12/2008 16:00:00
48 forum posts
65 photos
yes i mean no rudder  sorry should have said that  the props controlled steering.i hade a servo .receiver and switch kit from other boat ,but as it  has no rudder i dont know if have to fit another receiver to work steering. thankstom
60watt15/12/2008 16:29:00
253 forum posts
14 photos
You could fit a rudder  and drive two motors with a single speed controller.
To control throttle on two motors you would need two speed controllers.Then get a transmitter that allows you to unscrew and rotate the rudder stick by 90 degrees to make two throttles OR do some surgery by adding resistors to mix the throttle and rudder sticks together (cost is pennies) OR use the mix option if the transmitter has one.
Tom
Hugh Connolly15/12/2008 19:32:00
48 forum posts
65 photos
thanks tom been sitting looking at it again, i was thinking .adding two rudders servo ,speed controller. and two recievers one for each motor ,or is it one reciever and two speed controllers,one for each motor ,.hugh
mick15/12/2008 20:14:00
127 forum posts
74 photos
hiya hugh
what sort of space have you got in your hull because i was looking at one in u s a  same boat i
think  there is not a lot of room  in the hull you will probably have to put the small servos in and
check on the set up for room for esc  and batterys  i would double rudder it as you said
hope this helps mick
Hugh Connolly16/12/2008 00:07:00
48 forum posts
65 photos
thanks mick there is plenty room in hull when u take every thing out. wat would be the right setup,two speed controllers or two recievers.  cheers hugh.
mick16/12/2008 15:49:00
127 forum posts
74 photos
 hiya hugh
it depends on the set up you require you can  get a single  speed controller now  that does the twin
motors i think astec electronics do it not sure of the price i  do a couple of my boats on twin shafts
and twin motors but run them on single speed  controller  but this depends on the setup you require
i have other boat s on twin esc but that is on 3 or four channel setup  as i said its all about price
you are willing to spend and different motors esc and radio you are useing if you go to your local
model shop they will advise you or better still your local boat they  are always happy to help if you ask
the members hope this helps mick
60watt16/12/2008 16:13:00
253 forum posts
14 photos
Hugh,watt transmitters do you have?
ashley needham17/12/2008 06:48:00
7121 forum posts
206 photos
All . Yes good question....Do we take it that the boat works fine on its own but when other bods turn up and use their radios does yours then play up ?    Ashley
Restorers Wanted
Tony Green Steam
Shrek
