End point question
Neil Powell 121/07/2020 20:06:36
38 forum posts
3 photos
Hi,
I'm looking for a set of motors for my next project. On my last model i used a pair of mtroniks m600's which are rated at 12000rpm at 12v. As they were still too fast i set the end points on my transmitter to 30%. Am i right in saying that the motors will be limited to about 4000rpm?
Also has anyone got any experience of mfa metal gearboxes. Are they reliable and quiet?
Cheers
Neil
ashley needham21/07/2020 21:07:16
6611 forum posts
153 photos
Hi Neil.
What is the new project? We can’t even begin to advise you if we don’t know what it is,!
Size, weight, hull style, prop size, expected top speed etc etc
Dave Milbourn21/07/2020 23:01:25
4003 forum posts
282 photos
That presupposes that the ESCs are totally linear in response, whereas in my experience they seldom are. The only way to check is with a tachometer. You're better advised to fit slower motors or use less volts if you need less RPM because it's at the mid-speed range where ESCs get the most hot and bothered.
I've used the geared MFA motors and they most definitely are NOT quiet!
Malcolm Frary22/07/2020 10:04:51
893 forum posts
ESCs run coolest at their extremes - fully off, no current, no heat. Fully on, no switching, just creating heat by virtue of component resistance. Anything in between, they are switching on and off several thousand times a second, and it is during the transition time between on and off that they create heat. If they can't get rid of the heat fast enough, they get hotter. And hotter, over time.
Having the right battery, motor and drive train is important. Getting round bad choices by bodging electronically is always second best. Going for a drastic end point reduction will likey result in rough control. Digital stuff works in steps. Closing the end point makes for fewer, but bigger, steps somewhere along the line.
Charles Oates22/07/2020 15:26:15
567 forum posts
46 photos
Hi Noel, I might have missed something, but if the model is being overpowered to such a drastic degree, why not just reduce the supply voltage from the 12volts you imply you are using, to 6volts?
Charles
Neil Powell 122/07/2020 17:40:49
38 forum posts
3 photos
Hi thanks for all the replay. My new model(bait boat) is pretty much a reworking of the last one with some improvements e.g better access to electrics. The size is the same but I'm hoping the weight will be slightly less. I have ordered a tachometer now from eBay so I'll be able to see how much rpm they are running at.
Learn something new everytime I ask a question on here. Never knew that esc's worked harder when in the middle range.
In respect of the suggestion that I use 6v batteries I want to stick with lipo to reduce the weight a bit, could go from 3s to 2s I suppose.
Dave Milbourn22/07/2020 18:05:21
4003 forum posts
282 photos
Neil
You haven't helped us to suggest motors etc for your next project. Please read Ashley's post again for the information we would need. Saying "it's pretty much a reworking of the last one with some improvements" doesn't get us any further along the path, m'duck.
Dropping from a 3S LiPo pack to a 2S will significantly reduce the motor speed but there's probably some much more suitable motors out there. I wouldn't look at an MTroniks 600 for powering a bait boat, but that's just my personal preference. Some anglers like their bait boats to run very fast to get the bait out there quickly, while others like to creep up slowly and deposit it carefully and precisely.
Neil Powell 122/07/2020 18:22:06
38 forum posts
3 photos
Posted by Dave Milbourn on 22/07/2020 18:05:21:
Neil
Fair point Dave. It will be a twin hull bait boat at 800mm long and 375mm wide. Each hull is 110mm wide. It is plywood construction and should come in at 6kg.
I believe that the mtronik m600's will be running at about 4000rpm and that works just fine on the old boat(same weight and dimensions) and leaves a little spare for when it's windy etc. The props are 50mm twin bladed plastic things on a 5mm shaft.
I was hoping to find a way of running the motors at 4000rpm ish without messing about with the end points. I know people are going to say throttle control but thats easier said than done when you are trying to manage the line on the reels and steer the boat at the same time.
I'm more of a slow and accurate type of bait boater. don't like all that white water coming out the back of the boat and it not really moving any faster.
Neil Powell 122/07/2020 18:29:33
38 forum posts
3 photos
Neil Powell 122/07/2020 18:30:32
38 forum posts
3 photos
Tony Green Steam
Shrek
Restorers Wanted
