Andy F | 16/07/2020 15:44:28 |
55 forum posts 99 photos | I've managed to get bored with all my other creations so whilst wondering what I could do next I found a set of plans on the internet and thought... Hmmmm... like you do. I wanted something no larger than 1 metre in length (because I'd struggle to get anything bigger in the car) and this one came in at 1250mm or thereabouts so it had to be scaled down slightly. Not a problem and construction began in earnest. My preferred medium is plastic (shock horror) so all the various bits were scanned into a cutter and the parts made. I tend to use laminated 20 thou styrene which is strong but surprisingly light and easy to work with. I've already had a lot of help and advice from various people on another site (which shall remain nameless) but for reasons of actually daring to have an opinion about something, I was summarily banned. If anyone here was a contributor to my thread over there then I'd like to thank them for all their assistance. Anyway, the build so far: The superstructure (which is removable at this stage) is almost complete, the motors, radio gear and battery are in the garage waiting for me to decide where to place them. I intend to sort of plank the hull using long 4x2mm balsa 'planks' with a coat of epoxy on the inside for both strength and waterproofing. More bits: The rear cabin bar/lounge area. This will eventually be populated with G scale figures and properly stocked and illuminated. The rear sun deck area. This area will have a 'canvas' canopy draped over it eventually and maybe a table. The pilot house. All but finished with real wood cladding on the walls. Chintzy. The other boat. Not sure what to call this really. Is it a lifeboat? Is it just a get you to and from boat? Whatever, the basic shell is one my great uncle built about 50 years ago. All I've done is pimp it up a little with a rudder and a tarp.
That's it for now. There's lots more bits and pieces to do, not least of which is clad the hull and sand off those very rough deck planks but that's for another day.
Thanks for reading Andy |
Andy F | 16/07/2020 15:48:20 |
55 forum posts 99 photos | BTW in case anyone's wondering, Mahealani is a Hawaiian word which translates as heavenly moonlight or heavenly mist depending upon who you listen to. In my case it was a pleasant young lady in Lahaina, Maui a few years ago. |
Ray Wood 2 | 16/07/2020 16:57:29 |
![]() 2178 forum posts 761 photos | Hi Andrew, She is looking great, nice to see a new build of a classic boat, interesting to see you build the frame & superstructure first before planking the hull, keep up the good work 👍 is there another model boat forum? 😀😀😀 Regards Ray |
Andy F | 16/07/2020 17:16:02 |
55 forum posts 99 photos | Posted by Ray Wood 2 on 16/07/2020 16:57:29:
....is there another model boat forum? 😀😀😀 Regards Ray Not as far as I'm concerned
To be honest, I think doing the interesting stuff first is a mistake and it's one I always make. It's just that I get bored doing planks. Important stuff that I forgot to mention earlier. Twin motors (385's as per recommendation), twin rudders, 9.6v NiMH (again as recommended) and a Viper Marine 15 ESC. On Gaudy or what? Edited By Andrew Fallows on 16/07/2020 17:37:22 |
Chris Fellows | 16/07/2020 17:27:54 |
![]() 809 forum posts 532 photos | Yes, a nice looking boat and you're making a good job it. Chris |
gecon | 16/07/2020 19:38:21 |
276 forum posts 244 photos | Nice work Andrew, lovely wheelhouse interior detail. I know what you mean about the boring planking! I found a lot of excuses for painting and preparing crew members and small detail items in between long-ish planking pauses. The same while fairing the hull after planking was done. Needed smal therapy-breaks by doing some detail stuff. George |
Andy F | 04/08/2020 11:37:52 |
55 forum posts 99 photos | So I've finally made a start on planking the hull and what a tedious job it is too - put a few pieces on, wait for the glue to dry then repeat ad infinitum.... So in the meantime I've been playing with more interesting stuff such as... replacing the wholly unsatisfactory wooden deck with a more aesthetically pleasing plastic one. Stocking the bar... Building a tent... and figuring out where best to put the gorgeous Ellie. All these bits are currently still removeable so that when I eventually finish building the hull I will still have easy access to the interior for waterproofing and ballast etc. I do have one slight problem though. I set the aluminium plate (1st photo) to mount the motors on at the wrong angle and consequently the motors/propshafts are binding. Not good but easily fixable. |
Ray Wood 2 | 04/08/2020 12:12:54 |
![]() 2178 forum posts 761 photos | Hi Andrew, As I'm in the construction industry it's rather like building the roof first and then the foundations later, I always build the hull inverted on a board as it makes the planking more accessible, and gives me a platform to build the superstructure on, still each to his own, she looks a super job, shame about your motor alignment ! but I'm sure sure you will get over it Regards Ray |
harry smith 1 | 05/08/2020 02:34:05 |
1043 forum posts 1219 photos | Hi Andrew Nice boat and top work !!! I was scare off of planking to start with, but once I got into it. I found it was not that bad and I enjoy it. I use Ikea 3mm wooden blind which is like a hard balsa, but stronger and easier to steam and bend.
Harry Smith |
Andy F | 06/08/2020 22:42:35 |
55 forum posts 99 photos | So with all the superstructure removed, hull planking began in earnest today. One side is almost complete and I've done about 2" of the other side. This much has taken all day..... it's going to be a long job. My plan is once it's all planked then I will sand it all smooth-ish then cover & dope(?) it. Once I'm happy with that I'll skim it with Isopon and resin the inside. Any thoughts on this plan of action? I'm open to suggestions. |
