Motors / esc
brown river navy
Andy hop06/07/2020 10:34:58
21 forum posts
2 photos
Hi
I have just got a brown navy river boat that has twin props
Its around 37 inch long fibreglass hull whats the best motors to
Use & esc combo what it to plane a little . There is a photo
Uploaded in my albums
Thanks
ashley needham06/07/2020 10:47:40
7150 forum posts
164 photos
Hi Andy. There is no best combination to use. You will get likely several suggestions here, all of which are likely to do the job, and you make your choice.
What size props are you going to use, or at least, what is the scale prop size? As this has a bearing on the motor choice.
Do you have some batteries to use from (for instance) any other boats as this could also affect motor rating (Kv), assuming you would want to re-use batteries and not buy the Lipos which will be suggested.
Edited By ashley needham on 06/07/2020 10:48:25
Andy hop06/07/2020 11:05:39
21 forum posts
2 photos
I currently have 3s lipos and 35mm brass props 3100kv
Brushless motors, 2600kv brushless motors and others
And 70amp esc . Can i run t motors with there own esc lipo
And connected with a y lead to the receiver ?
Many thanks
Dave Milbourn06/07/2020 12:06:18
4025 forum posts
282 photos
Andy
I would say that none of the motors mentioned is suitable, being much too fast for the props you propose - 11.1 x 3100 = >34,000 RPM. If you want to make use of the 3S LiPo packs then the motors need to be more like 750kv - 1000kv outrunners. You will need one ESC for each motor and it makes sense then to have a separate battery for each, connecting the ESCs to the receiver with a Y-lead. Do make sure that you disconnect the red wire in the 3-wire Rx lead from one of them to avoid the receiver being fed two different voltages from the BEC circuits.
BTW the photo isn't vey informative but that hull doesn't look like it will plane very easily. Is it a hard-chine hull?
Andy hop06/07/2020 12:39:06
21 forum posts
2 photos
Dave its a fibreglass hull added more photos .
Thanks very much
Andy
harry smith 106/07/2020 13:02:43
1072 forum posts
1272 photos
Hi Andy
Dave is right, 1000kv 35mm brushless motor !!!
I am using the sister motors C3542-1250kv from Banggood and they are a dam good motor.
The C3542-1000kv(2 to 4S Lipo batteries) 750 Watts on 4S with a Max 55 Amps.
The 70 Amp ESC will fine.
I have a single 1250kv in a 30" Huntsman it's more speedboat than a Cruiser on 3S.
I tested it on 4S and it's a rocket.
Harry Smith
Dave Milbourn06/07/2020 13:16:35
4025 forum posts
282 photos
Andy
That's likely quite a heavy boat and will require some serious oomph to get it onto the plane. I might suggest something like two of these Overlander Motors Although I've not used this manufacturer's stuff before, I gather they are a reliable supplier of good equipment and they've been around for ages - that's usually a good sign.
I have one similar spec Turnigy motor in a 36" Fairey Huntress. It runs a 40mm 3-blade prop on a 3S pack but it's a very light model and planes like the big 'un.
harry smith 106/07/2020 14:03:59
1072 forum posts
1272 photos
Hi Dave
Turnigy motors are good, but try and buy one at present !!!!
That's why I got the C3542 from Banggood and another four arrived last week.
Harry Smith
Dave Milbourn06/07/2020 14:31:01
4025 forum posts
282 photos
Yes, Harry - I found that out when looking for the webpage for the one I fitted into Huntress. I'm told by Chris Fellows that the Overlander ones are very good, and the website certainly shows them as In Stock.
Tony Green Steam
Shrek
Restorers Wanted
