Tim Cooper | 07/04/2020 14:38:17 |
![]() 388 forum posts 171 photos | Made a start on an Eezebilt OSA 1 Missile Boat, whilst in lockdown and a change from gardening. Tim
Bob Abell | 07/04/2020 15:51:01 |
![]() 8951 forum posts 2824 photos | Is this a kit, Tim? It looks quite large too Bob |
Tim Cooper | 07/04/2020 16:46:46 |
![]() 388 forum posts 171 photos | Bob It's an Eezebilt plan printed off the website on my home printer. So cut the plan up to make templates.It's 32" long and I am using 3mm lite ply for the framework, then 2mm for the hull sides. Not decided what to use for the super structure. If you put Eezebilt boats into Google you will see the website. Tim
Edited By Tim Cooper on 07/04/2020 16:53:00 |
Tim Cooper | 14/04/2020 12:51:37 |
![]() 388 forum posts 171 photos | I have been looking at the prop tube needed for the OSA and it looks as though I may need a14" tube. Never having used one this long will it need to be supported along its length. Or should I try to find a way to use a shorter one? Tim |
ashley needham | 14/04/2020 13:16:01 |
![]() 6843 forum posts 200 photos | Tim. I personally wouldn’t use a 4mm shaft/tube at that length, a5mm one perhaps. Could you use a shorter tube and have to ‘bare’ shaft inside, possibly supported with a bearing or even a bit of brass tube? This would effectively give you a centre bearing, and the tube does not need to extend inside for any length?
Ashley |
Colin Bishop | 14/04/2020 14:08:26 |
![]() Moderator 4708 forum posts 6077 photos 402 articles | Re Ashley's point above, Model Boat Bits allow you to mix and match shaft and tube lengths: https://www.modelboatbits.com/PROP-SHAFTS/ Colin |
Tim Cooper | 14/04/2020 14:36:34 |
![]() 388 forum posts 171 photos | Thanks Ashley / Colin I wondered how you could buy different lengths of tube and shaft. I will have a look at Model Boat Bits. Tim |
Tim Cooper | 15/04/2020 14:33:22 |
![]() 388 forum posts 171 photos | Ashley / Colin Sorted what I need to order from Model Boat Bits. Thought I might as well get the appropriate support at the same time. Would an A frame support be better that a P support or is there not much to choose between them. Tim |
Dave Milbourn | 15/04/2020 15:13:01 |
![]() 4025 forum posts 282 photos | Tim An A-Frame is much better support than a P-bracket but at this size it's more a matter of appearance. Dave M |
Ray Wood 2 | 15/04/2020 15:22:55 |
![]() 2176 forum posts 760 photos | Hi Tim, I'm guessing the central keel doesn't support the stern tube at all when it exits the bottom of the hull ?? It does seem to be a very long stern tube at 14" almost half the length of the boat it must be at very shallow angle. The way round this is to extend the keel to form a skeg which also protects the propeller. Regards Ray |
