Motors & Overheating
Fatcat05/08/2008 10:13:00
41 forum posts
Hi again,
well just been setting up my running gear and have noticed that even when the motors are not running, (just sat there on standby with batteries connected etc.) and have noticed that the motor casing is getting really hot. also the connected speed controller is getting quite hot. i have looked for short circuits but theres nothing obvious. i'm running a seperate circuit for each motor.
 I'm using torpedo 850 motors, electronize fr30hx esc's, 12v 7ah batteries all connected by 30 amp choc block connector and fuses. ive just disconnected everything and motor is still really hot, theres a lot of residual heat comming out.
any ideas?
Dan
Bob Abell05/08/2008 11:11:00
9317 forum posts
2976 photos
Switch off ..........and wait for a reply!
Have you got fuses in the system?
Interesting?
Bob Abell05/08/2008 11:15:00
9317 forum posts
2976 photos
Sorry ...I see you have mentioned the fuses
Bob Abell05/08/2008 11:18:00
9317 forum posts
2976 photos
The block connector sounds suspicious?
Why have you connected both batteries to it?
Paul T05/08/2008 11:30:00
7334 forum posts
1229 photos
2 articles
Hi Dan
It sounds very much like a short through the motor casing.
Are the batteries getting warm?
Try using a volt meter to check how much current is being drawn.
Could you post a circuit diagram showing how you have connected everything and list the parts giving all of the separate ratings and specs so that we will be able to help you better.
Bob Abell05/08/2008 11:34:00
9317 forum posts
2976 photos
Hello Paul..........How are you today?
Can you understand the block connector involvement?
All the best,,,........Bob
Fatcat05/08/2008 11:36:00
41 forum posts
Hi Bob
 I havnt!  From the esc, theres a red and black wire. The black goes to neg battery and the red goes to a 30 amp fuse and then to the pos battery. There is also a blue and yellow wire, these go into a choc block and then into the corresponding motor wire. i.e yellow for pos and blue for neg. This is what i class as a circuit of which both motors are seperated on their own battery, esc, fuse and choc block.
The choc block is a new one as the previous sort of melted on me, (must have only been a 15amp baby), so i bought this new one i am using whish is rated at 30amp as per ESC and fuses. All well so far as there is no melting plastic.
It might have been from when i was running the motor and then the heat slowly comming out but i swore it was getting hotter when it was still. How hot should these motors get? When i first put her on the pond i was ragging the arse of it as the props i had arnt very good and it didnt go anywhere... of which they have been changed today and are 100 times better. After it had been on the pond, I  felt the motors and they were red hot, i couldnt touch them for more than a second.
Dan
Fatcat05/08/2008 11:39:00
41 forum posts
Paul, wiring as per above....
batteries are fine, infact i did check them to see if they were warm but they are fine. another thing is aswell that i do have some motor suppression resister things but havnt yet soldered them on as i'm just really fitting out the hull etc..
Dan
Bob Abell05/08/2008 11:41:00
9317 forum posts
2976 photos
Hello Dan
Connectors shouldn`t melt?.............Suspicious still!
Have you overfilled the prop shafts with grease?
Fatcat05/08/2008 11:43:00
41 forum posts
Oh and the original purpose of the block connector was basically for future connectability i.e sound unit or something like that as they are connected to the ESC but at the moment, theres nothing connected apart from motor.
Restorers Wanted
SLEC
Coastal Shipping August 2021
