Binding Orange to Spektrum
Martin Field 115/06/2018 18:26:26
564 forum posts
6 photos
Hi all,
I guess it had to happen, me being endlessly unfortunate where electrics are concerned.
A while back I bought myself a Spektrum TX a DX5e, then I bought a then very affordable Orange 6 channel Rx. I don't need 6 channels, but then I was also considering some aircraft activity.
Neither have been out of their packaging since they arrived as I only really do boat stuff in Summer.
Well, today I got together Tx. with batteries, RX. with a 5 cell pack (the Rx is fine from 3.7V to 9.6V. and a watch of youtubes and a read of the instructions. I did all that was presented to me and of course, nowt 'appened. The flashing of the Rx. didn't stop. I toggled the trainer lever and switched the TX on as instructed. The Tx. biddlybooped and it's lights came on, though Gawd knows what that means, but the Rx. just kept on flashing till my back ached too much to carry on sitting still.
What am I doing (or not) wrong? Anyone got any ideas, because I don't "do" problems. I expect stuff to work or it's out the window. Often followed by a large hammer, just to make me feel good. But this stuff is all new, never been used.
Help?
Cheers,
Martin
Paul T15/06/2018 19:21:40
7143 forum posts
1206 photos
2 articles
Martin
I had no end of trouble trying to bind orange to Spektrum, standing on one leg, in a bucket, at the bottom of the garden, on a day with a B in it, switched off everything that uses 2.4 and sacrificed a hamster to the great electronics god.
All no good.
I came to the conclusion that orange is just to awkward to use so I did some fine tuning with my sledge hammer.
So I keep my multi channel systems for helicopters and bought a super 2 channel 2.4 from Steve Webb for the boats.
Martin Field 115/06/2018 19:32:51
564 forum posts
6 photos
Not really what I was wanting to hear, Paul, though a pc of you on one leg at the bottom of the garden would have been good.
So I have to look at my old 27 megs or buy again? But it's all new!
I'll check the cost of a Spektrum RX. Or even an Orange Tx.!
But I've spent a lot on getting some basic stuff in this damned tub and no closer to a working set-up. I HATE working models. Always have. Free sailing has a lot to recommend it. I like building. Don't really give a stuff about playing toy boats...round and round and figures of eight till the batteries run out...wake me up when it hits the bank could you?
Martin
Paul T15/06/2018 19:42:49
7143 forum posts
1206 photos
2 articles
Martin
The new kit that I bought is wonderful as it does everything it is supposed to do without any fuss (or standing in a bucket) it is literally plug and play.
Its just as simple as the old 27meg but without the interference and is a real joy to use.
Martin Field 115/06/2018 20:02:31
564 forum posts
6 photos
Paul, I can't justify spending another 40 quid when I have 2 brand new items that simply don't work. Someone must know what to do.
Martin
Andy C15/06/2018 20:35:07
472 forum posts
116 photos
Hi Martin
Quick search of Youtube found a couple of videos. One where the bloke did not actually speak. Just twiddled a few buttons and hey presto. This one however did actually talk. See if it helps.
https://www.youtube.com/watch?v=Er0GeSj0cNw
Paul Freshney15/06/2018 21:19:56
293 forum posts
15 photos
Martin
I have had no problems whatsover binding a current manufactured Orange receiver to a Spektrum dx6, dx7 or dx8 Tx and have 3 in current use.
I stress the word ‘current’. The current Orange receivers will only work with DSM2 & DSMX protocols, which is the current operating system for Spektrum radios. Older radios, perhaps 5+ years old, were DSM and the newer (current) receivers will not work with the older system and vice-versa.
So, I would suggest you first check that both the receiver and Tx are the same protocol and that will be clear from the specification label on the receiver and the Tx manual/ front/rear cover.
I would also assume you have plugged in the binding plug to the receiver as nothing will happen if that is missing. It has to go in the bind socket and I had one really cheap orange receiver bought from the back of van (yes!) that had the label on back to front.
Finally, if I remember correctly, some early version 1 orange receivers had a button you needed to push, to also facilitate the binding process,
If the answers to the above bring no luck, then I have no idea what is wrong - sorry.
Good luck
Paul Freshney.
Martin Field 115/06/2018 21:55:46
564 forum posts
6 photos
Paul, thanks for your thoughts. The Orange Rx. is DSM2, I think, either that or DSMX. The Spektrum DX5e is DSMX, but its instructions insist it is completely compatible with the alternative protocol. Do you happen to know which way round for the label is correct? I have read of that being found in other cases. Mine has the bind plug in the left side as you look down on the top surface with the plug section towards you. It says BIND/BATT.
I can afford to cast out the Rx as it only cost me £8, but I will have to find an RX. that will bind with the Tx as the Tx. was not an amount I am prepared to write off.
So, now I need to find something that will definitely bind with the Tx.
Cheers,
Martin
Martin Field 115/06/2018 22:34:13
564 forum posts
6 photos
Well, I just bought some Chinese (ain't it all) Rx. that actually specifies my Tx. for compatibility. It's called an S603. I will also get some heavy duty alkalines for the TX. when the new Rx. arrives as it might be that that has stopped the binding of the Orange. I have no idea what the lights on the TX. refer to.
I can spend the weeks before it arrives from Hong Kong discharging and recharging my new rechargeables for the boat system's RC (sail winch and steering only, I'm really not ready for ESCs).
Cheers,
Martin
Paul Freshney16/06/2018 00:18:55
293 forum posts
15 photos
Martin
I am currently not at home, away at our daughter’s, but I think your description of how you see your Orange Rx is correct.
With regard to a receiver, obviously a Spektrum original branded one should always work, but the cheapest is now c£30 or so.
If all else fails, then Al’s Hobbies are now the UK agent for Spektrum and offer a service facility I understand.
A couple of other thoughts:
The Tx and Rx actually will sometimes NOT bind if too close together on the bench. A metre or so apart is best, and the same applies when switching on at the pond side, that is assuming you have got it all working ok at home!
Batteries? If you have flashing lights on the Tx and Rx, then I would guess they are okay.
Finally, I stopped using the oblong orange receivers with a very short aerial (I only paid £4!) because they were/are park flyer, ie relatively short range. Currently I am using the orange 6 channel telemetry enabled receivers in two hulls because at £17.70 each from HobbyKing they are a third of the price of the genuine Spektrum version, one of which came with the Dx8 Tx, These Orange £17.70 receivers have two quite long aerials and are described as ‘full range’.
Very finally, my experience with r/c is that it is handy either to have two of everything, OR to have a friend with the same brand of system, because you can then compare the two to find the fault. For example, you currently don’t know for sure if the Tx or Rx is at fault, even though as you say, the Tx is making all the right light signals/noises and it is probably therefore a receiver problem.
Cheers for now - back to baby sittting...
Paul.
Shrek
Tony Green Steam
Restorers Wanted
