cooling system
Jake Knight06/06/2008 13:28:00
90 forum posts
24 photos
hi guys
is thare any way to make your own cooling rings for the motors?
because i want to keep costs down
Charles Oates08/06/2008 09:36:00
642 forum posts
52 photos
Hi Jake, I presume you want this for electric motors.
Get a length of small bore copper tube aroung 2 mm i/d. Heat it to red hot and quench it in cold water. This will make it ductile, or easy to bend. Wrap a few turns around the motor,  and lead the ends to a suitable location for conecting up. that about does it.
This method has been used for decades and works very well.
 Chas
Jake Knight08/06/2008 15:44:00
90 forum posts
24 photos
 i though i could do it some way like that
do you know where i could get the copper pipe from as my local hobbie shop only sales brass
thanks
jake
Paul T08/06/2008 20:29:00
7335 forum posts
1229 photos
2 articles
Hi Jake
Try your local plumbers merchant and ask for 6mm OD microbore pipe this will give you an internal dia of 3mm, but as 6mm is quite rare these days you might have to get 8mm OD which will give you @ 5mm internal dia.
Follow Chas's instructions to make it ductile and to make the bending easier and to avoid squashing the pipe walls try packing the pipe with dry sand, this will support the pipe walls whilst you bend it around the tight dia of a motor casing.
However in this modern age plumbers merchants also have microbore plastic pipe which is heat resistant and easy to bend.
Good luck
Jake Knight09/06/2008 10:07:00
90 forum posts
24 photos
thanks paul i was worried about the walls bending inwards
thanks paul
Paul T09/06/2008 11:06:00
7335 forum posts
1229 photos
2 articles
Hi Jake
No problem just remember to seal the ends of the pipe up before you start bending it.
Cheers
Jake Knight09/06/2008 15:35:00
90 forum posts
24 photos
why do you have to seal the ends up
is it to not let the sand out?
thanks again
jake
Paul T09/06/2008 19:20:00
7335 forum posts
1229 photos
2 articles
Sorry Jake
I did not explain myself very well, the process of sand filled copper pipe bending requires that one end of the pipe be sealed or stopped up (with a good bung) then you fill the pipe with sand and ram it in tight and then you bung up the other end so that the sand can't come out whilst bending.
Once you have finished all the bending then you remove both bungs and get the sand out.
Hope that this is clearer. (I am a dufus sometimes)
Manxman09/06/2008 20:50:00
440 forum posts
133 photos
B&Q sell 6-8-10mm micro bore copper pipe for heating systems, check their web site www.diy.com
I have to admit though I've never seen cooling coils so thick,  I've only seen them in 3mm copper and 4/5mm aluminium - for the smaller pipe try your local car scrap yard.  Oil pressure gauges always used them on the older cars, just need a Little cleaning with hot water and washing up soap !
Cheers - Ken
ps - just checked B&Qs site and they are not listing 6mm - though they do sell it in the bigger stores, you may need to try a normal plumbers store.
Bob Abell09/06/2008 21:01:00
9337 forum posts
2985 photos
These cooling coils ...ready made ....are availabell in most model shops.
As a matter of fact ........But....I`ve never fitted a cooling tube to any of my motorised models?
Bob the Hothead
Coastal Shipping August 2021
SLEC
Restorers Wanted
