Cutting plastic tube
Paul7526/04/2016 22:24:19
97 forum posts
10 photos
Hello Everyone
​I thought I'd use 10mm cut lengths of 20mm diameter plastic tube to make the 20 or so cylindrical Oerlikon nests for my 1/128th HMS Duke of York because I thought it'd be easier than shaping styrene sheet.
​However, much to my frustration, when I cut this tubing using a razor saw and mitre box, with the tubing clamped in place, I find that the cut is not perpendicular to the length of the cylinder and I get a wonky result.
​Given the care taken to achieve a straight cut, I'm at a loss as to why the cut is off kilter.
​Can anyone please advise me where I'm going wrong and/or a better method to obtain the result I'm after?
​Many thanks,
​Paul.
mark6926/04/2016 22:35:51
182 forum posts
71 photos
Paul maybe the blade is bending, try cutting 1mm bigger with a hacksaw and sand down to the correct length ! ....mark
Edited By mark69 on 26/04/2016 22:37:15
Colin Bishop26/04/2016 22:59:58
4757 forum posts
6078 photos
404 articles
Sawing is always a problem to get right. Much better to invest in a a mini tube cutter. These come in two sizes, one for very small tubes and one for larger ones.
You can see a selection here.
https://www.amazon.co.uk/Tubing-Cutters/b?ie=UTF8&node=1938882031
Once you have one you will wonder however you managed without it!
Edited By Colin Bishop, Website Editor on 26/04/2016 23:01:50
David Marks 126/04/2016 23:54:21
255 forum posts
44 photos
As 10 mm is a standard thickness for plywood and 20 mm is a standard diameter for a wood drill bit i.e. the flat bit type. If you have a pedestal drill, then drill a 20mm hole in the ply, cut a length of tube over length, pace in the holes and file flush with the surface of the plywood.
Francis Macnaughton27/04/2016 13:31:02
110 forum posts
Otherwise, if you can get hold of some lithoplate from a printers this can easy to cut into rectangles and bent around a former to the required shape.
Paul T27/04/2016 15:32:44
7188 forum posts
1214 photos
2 articles
Hello Paul
The reason for the wonky cut is that your blade is bending as you are cutting, its not your fault as plastic tube is notourious for having this effect on thin blades.
Tube cutters are a good option but can crush some thin walled or rigid plastic tube.
The best hand tool is an engineers hacksaw with a 1in deep blade
This is the type of hacksaw with a standard blade
The deeper blade is shown here below the standard blade
Hope this helps
CookieOld27/04/2016 18:49:53
297 forum posts
70 photos
Hi Paul , Welcome to the club, it,s not easy to cut dead true , i always part off on my lathe , or scribe a line around the tube and follow that with your saw while rotating the tube.
Dave wink
Paul7527/04/2016 21:27:19
97 forum posts
10 photos
Hello Chaps
​Thanks for your replies and advice. I'll be buying a tube cutter and 1 inch hacksaw blade and see how I get on with these.
​All the best,
​Paul.
Colin Bishop27/04/2016 22:33:16
4757 forum posts
6078 photos
404 articles
Tube cutters generally work OK with plastic tube if you take it gently with a series of light cuts. There is also the option of putting something inside the tube to support it while you make the cut, a length of dowel, rod or knitting needle for example.
Tim Cooper28/04/2016 08:46:38
394 forum posts
171 photos
I use the KS Metals tube cutter for plastic tube. It gives a smooth clean cut. As Colin says just take it slowly, tightening the blade against the tube a bit at a time.
Shrek
Restorers Wanted
Tony Green Steam
