Member postings for mick
Here is a list of all the postings mick has made in our forums. Click on a thread name to jump to the thread.
Thread: Veron Kits
18/02/2008 18:31:00
i have done the figures in two different styles no 1 is white top and shorts with tin hats on
except the captain with flat cap and dark blue navy shirt white shorts hat white top middle blue and
peak black for warmer climates i e med and brown shoes
the second way is get the milliput fine out the sailors tops to jumpers and long trousers
the jumpers navy dark blue and grey trousers and black shoes
the boat were made in the 50+ 60 sixtys not sure of dates but other members might know
hope this helps anymore questions please ask i bulid a s r launches w w 2 these boats
were from the fiftys +sixtys era target towing launches r a f section hope this helps keith
Thread: Rusty hulls
13/02/2008 21:09:00
to bob abell to create rust i leave a couple of old nails out in the weather when they rust
i wire wool it off into a lid then put clear matt varnish then just spinkle it on the require parts
instant rust hope this helps mick
Thread: Italeri PT596 kit
08/02/2008 20:09:00
hiya ernest koch
model boats did a 100 page kit special get a back copy of the winter 2007 issue
this has a full articule on converting it to full r/c operation of the new
iltaleri elco pt -596 hope this is of help mick
Thread: Veron Kits
08/02/2008 19:58:00
hiya keith
the figures you want from caldercraft or mountfield models they do 1/32 scale figures w w 2
or convert 8th army airfix multipose figures they have officer and crew with tin hats on
Thread: Off to a good start?
01/02/2008 18:22:00
hiya ej found the plans for a medium landing craft mk1
the length is approx 29"+8"=4"high plan 2083
by l g brown  august 1986  if this of help
it is a two sheet plan original craft was length 41 6" by 10 0" speed 10 knots
armament -two0.5" m/gs& one 4" smoke mortar or one 20mm oerlikon gun
Thread: Glue
25/01/2008 21:25:00
hiya john mick here
look under   plastidip.co.uk this might help your problem  they have some amazeing
stuff hope this helps you
Thread: Find out about a boat
20/01/2008 19:43:00
hiya dave my missus bought me an mfa 850 motor she said to stop me
going to the the scrappy i have made a cooling coil and have a 55 two bladed prop
a 17" prop so we have a goer thanks for input again mick do you think it will need
the 12v motor suppressing? just wondered not used to 12v
17/01/2008 22:27:00
hiya e j mick here
i have some plans somewhere of a free scale armoured L C in my selection of
plans they are plans i bought years ago i am going to build one shortly but if you
want i will find out how much they will cost to get copyed if you want they are in
two sheets ok as for e bay ihave being useing it for a couple of years now and
as long as you check the feedback of the venders if they have less than 98% i will
not buy i have some great batterys from component-shop i found on ebay
hope this is of help mick look on webshots.com and look under mickrik05 my
albums and check out the figures on the asrlaunch
16/01/2008 17:51:00
hiya dave  the cost is a bit of a put off on fixed income not much money  to
spend but if you dont think this will give me enough power  i was thinking
of a 12v heater motor from the local scrapyard  about a fiver supressed
of course my mate runs his his 40"brave border he get about 2hrs + on a
12v 3amp hr battery  just let me know what you think thanks for your input
mick
15/01/2008 20:59:00
hiya  dave  had a change of mind? still going to build like a
chris craft but decided to put a 12v 777 from models motors direct on 12v
a single shaft and single rudder had them spare and just have to buy prop+
12v battery thought i would use a 12v 7amp hr battery because i want to light
it from the same battery 12v grain of weat bulbs going to use a y lead to switch lights on
as i have a two channel radio set i had out a nother boat and a resistor type speed
control as well thanks for your input mick
14/01/2008 17:04:00
to dave mick here  i thought it was a sea queen  but the cabin is
completely different and the hull is 42" length i suppose i will
have to make a boat that is a mixture of differrent boats thanks
for the input i thought i would base it on a chris craft design
i have two hecterperm s on 6v and twin shafts and twin rudders
its big enough for two 6v 8amp batterys  thanks again
01/01/2008 21:53:00
hiya martin google model fireboats and you will find a website for these boats
they should be able to sort you out some plans  thereis also another website
on  yahoo in groups hope this is of some help mick
16/12/2007 21:44:00
if you want 1/32 figures look on ebay was a from cumbria who makes figures
for marine ,modellung the tug man hope this helps if not i will get you his
his telephone number i used the figures on a ww2 a s rl and they are realy well
made made of resin and on stands so it helps when painting them hope this
of help with the modellers
Thread: star system on plans
20/11/2007 16:11:00
hiya david
   if u look on ebay for great plans he is in canada he has plenty of plans for sale
of which if you wont a bigger scale he will update the plans for you hope this
10/11/2007 20:19:00
i have just finished some  us navy figures which would look alright on any us navy
boats i modify these from different model kits on the market at the moment i am selling
on e bay at moment
Thread: Plans required
28/10/2007 17:45:00
look up great plans (2243) on ebay i have him saved in my favourite sellers uk ebay
i was look at the cd he had for sale not just plans but write ups on the various
boats a s r launches w w 2 price is £7.07 buynow +p+p of £1.46 but i takes ten days it comes from canada hope this is of help anymore you want to know please ask
Thread: Fitting out hull
27/10/2007 21:58:00
i have a 42"+12" hull i have two decoperms spare and was going to put these in
but could do with some advise with length of shafts +how big the rudders should be was
also going to put in two 6v 4amp hr batterys in  but would i get enough running time ?
i also wondered what props to use and was going to put two bobs boards in to keep costs
down what rateing should i use  well hope you lads can help tryig to keep cost down as being on a fixed income thanks for your time
19/10/2007 22:51:00
still trying to find out what  this boat is called surely somebody must have seen this
old boat in the past  just started planking the deck but dont wont to change the
cabin till i know what its called thought the gentleman from the collectors and vintage
corner might have an idea what it called thanks everybody mick
Thread: Mick's Album
19/10/2007 22:44:00
i hope you can help i have tryed all the normal sources but nobody out there seems
to know what its called  i have just started to plank the deck but didnt want to
change the cabin till i know what the boat is called and maybe get some plans if
possible otherwise it will end up a one off boat that nobody knows what its called
thanks for your time hope to hear from you soon mick thanks steve the only reply
i have received
Thread: Schnellboot 1/24 Scratchbuild
07/10/2007 20:03:00
  hiya stuart i have had some fitting custom made by a gentleman
on e bay you can always ask him he makes a  good job his handle on ebay is
boatmanwales hope this of help mick
