What type?
| ashley needham | 13/01/2008 09:04:00 |
1144 forum posts 86 photos | I am building a "Turbinia" at approx 50 inches long, from plans which do not show any internal running gear. I have sourced 3 shafts and 9x 30mm props(actually should be 25mm or less, but they look terribly small) but am undecided as to what motors to fit. I have bought some excellent 555 motors from model-motors direct, but these would need to be run at 18v to get the sort of revs I THINK I need for this comination.. any ideas? i have seen some pictures of another Turbinia but alas no details. If it was a case of one prop per shaft, I would possibly use some speed 400`s, but ?? I also want a reasonable endurance, so need economical engines. Am I being a bit hopeful? Any ideas..someone out there must have seen/built one! Ashley |
| The Fat Controller | 13/01/2008 09:49:00 |
1876 forum posts 235 photos 2 articles | Hi Ashley How heavy will the boat be when completed and do you want "scale" speed or something that is just fast. Paul |
| ashley needham | 13/01/2008 12:28:00 |
1144 forum posts 86 photos | Oo er, I never bother to calculate likely weights and so forth! the hull (bare) is 50" by 4 3/4 inches, an about as deep, and weighs 600g, 3x555 motors, for instance are 600g, 1x 6v 4.5Ah gel battery 750g, probly use at least 2 of them.. running gear and radio stuff (BEC for reciever) not an awful lot...probably a small amount of ballast to trim. I would like it to be reasonably fast, as obviously the original was the fastest craft in its day so you would want it to cut a dash and lift the nose clear of the water. What would SCALE speed for Turbinia be? I suppose it wouldnt have to be as fast as a planing Vosper type p/t boat. Ashley |
| The Fat Controller | 13/01/2008 20:23:00 |
1876 forum posts 235 photos 2 articles | Hi Ashley The Turbinia realised a speed of 35knots with a total of 9 props (3 on each shaft) At 50in I would sugest a scale speed of 8 >10 mph which would produce an exact replica of the full size speed, to get to this I would advise a 700 center motor and two 400 wing motors coupled to 2 speed controllers. Paul |
| Telstar | 15/01/2008 15:53:00 |
122 forum posts 16 photos | Hi Ashley Turbinia was 103ft 9in long, so your model at 50in will be about 1/25 scale. Using the scale factor can give you some idea of other characteristics of your model . With the real thing weighing 44.5 ton (and if I can do the sums right) would give a model weight of 6.4lb (2.9Kg), also the real boat had 2000Hp which scales down to 97W for the model, so using 6V each motor (3 in total) would draw about 5A when loaded properly with appropriate props. The props (3 on each shaft) are 3 bladed with relatively narrow blades, Parsons had a lot of trouble with cavitation initially, so spaced the pairs of blades well apart, each prop was 18in dia with a pitch of 24in this would be a blade angle about 30deg, Turbinia is in the Discovery museum in Newcastle with some info on nationalhistoricships.org.uk/index.cfm/event/getVessel/vref/138 I used info from the eng dept network , some is on the web atwww-g.eng.cam.ac.uk/125/1875-1900/turbinia.html Using dead reckoning will not give exact answers but should be used only to guesstimate answers.Best wishes with your model hope to see photos of the completed projectCheers Tom |
| ashley needham | 15/01/2008 17:09:00 |
1144 forum posts 86 photos | Chaps, thanks for that. I must say I had not thought of using two different sized motors..you reasoning being main propulsion on the centre shaft and just keeping the sides spinning? I like this idea as I am worried that all those props will get in each others way. I think I might provide motor mounts to accomodate various motors so i can swap and change for best performance. I will have to bone up on connecting two speed controllers together..is there a proportional unit I can get so that, for instance up to half throttle would mostly go to the centre motor and anything more would progressivly power up the sides? Great site the discovery museum. will bookmark. Ashley |
| ashley needham | 24/02/2008 15:11:00 |
1144 forum posts 86 photos | Chaps. I have discussed the motor options with various bods now and I think I will go (initially, at any rate) for 3x 600`s of some sort. In actual fact i will leave room to try other stuff, so it will only be a starting point. The problem at the moment is that I had a nice set of 9x30mm cast brass props and 3x3mm stainless shafts but the props have insufficient meat on the boss to grub screw them on with. I am considering using brass shafts and soldering the two mid-shaft props on instead..any thoughts on this? I am a bit worried that the wear may be a bit fierce, althought most of the bearings are water lubricated and the top can be kept oiled up.....? Ashley |
| The Fat Controller | 24/02/2008 20:04:00 |
1876 forum posts 235 photos 2 articles | Hi Ashley If the submerged bearings are constructed as a short prop tube i.e. with caps on each end that the brass shaft can pass through then you could use Vasoline or Lithium Grease as a lubricant. Paul |
| ashley needham | 22/04/2008 19:19:00 |
1144 forum posts 86 photos | Boaters. Two questions now .a) the plans I have show,or suggest "cyclone 20" motors running at 6v.What would be the modern equivalent of them, and does anyone know what sort of power/revs these motors developed? b) The plans do NOT show, but I have spotted on various photos, an exterior rudder quadrant on deck, pulled by steel cables. Handy this as room below decks aft is decidedly sparse...but what should I use to pull this quadrant around with??? Nylon line, small chain, polyester yarn? As an aside, in 1902 the boat was re-propellored with just three slightly larger props (one per shaft now) so i may have a fallback plan.....!
| ashley needham | 24/04/2008 19:15:00 |
1144 forum posts 86 photos | I have had a brainwave and am going to use fishing stainless steel flexible wire trace line for the steering. Should be just the job. I only need to know about the Cyclone 20 motors now..... |
