Holmewood Landing 24
I need a front view of this
Search for:  in  in
Phil Winks 116/05/2009 11:42:58
681 forum posts
269 photos
Half way through my Barrelback build and already I'm looking for another Launch to build. what I've sort of plumped for is this.
Unfortunately I can so far only find these 3 views of it and could really do with a head on front view. (much like the stern view) to import to my cad prog so as to get the bow shape dead right can anyone point me in the right direction please
Phil Winks 118/05/2009 17:15:35
681 forum posts
269 photos
Due to the apparent lack of details and further photos of this craft I've resorted to projecting the bow lines over the stern view using measurements from the plan and stern view.
This has enabled me to produce a complete set (well almost) of formers and a keel outline
also for reference I've produced a set of outline tracings of the plan and side view these will be used to produce the horizontal frame outlines.
Now given that I plan to build at 1m long and use plank on frame construction can anyone see any pitfalls that I may have not forseen
Bob Abell18/05/2009 18:06:55
1996 forum posts
596 photos
Hello Phil
Just a thought......................Where are you going to fit the motor?
I like the colour scheme...btw
Phil Winks 118/05/2009 19:51:46
681 forum posts
269 photos
Hi again Bob If you look closely. Its not that clear with out enlarging the pics to full size they're screen shots from a cad set at A0 (thats like 1100mm wide) the dark line on the side view is the propshaft line and above it and facing the front is a rough outline showing proposed motor pos. the idea is use a belt drive. and positioned where it is between F4 and F7 it sits under the control deck I hope. Still lots more drawing to do, still I've got till August at least.  How easy is it to prevent water entering through the prop shaft if the inboard end is below the waterline? I assume it must be possible.  I hope!!!
Phil Winks 106/07/2009 17:50:20
681 forum posts
269 photos
Well 3 weeks has passed the barrel back has passed her sea trials and a month or 2 ahead of schedule most of the hardware and planking for the Holmeswood are winging their way to me courtesy of various members of the ever popular internet auction site. The plans are complete and have been printed and the timber for the frame will be purchased by the end of the week so watch this space chaps et al
Bob Abell06/07/2009 17:56:03
1996 forum posts
596 photos
Don`t forget the driver!........Bob
Phil Winks 107/07/2009 08:01:12
681 forum posts
269 photos
I'll do my best Bob but can't build any bigger due to workshop restrictions and that means this will be 1/7th scale so maybe those 1/6th figures at CMB won't look out of place. Pricey though at a tenner apeice   a driver and a few passengers would soon add up  my current budget looks like being in the region of £60 so 3 figures would add 50% quite a lot really so what price realism
Bob Abell07/07/2009 08:09:18
1996 forum posts
596 photos
Hello Phil
How long is your model at 1/7th scale ?.......what motor etc
I`m now building the 1/6th scale Slo Mo Shun and certainly will have the obligatory driver....I`m hoping to have the driver turn his head with the rudder and steering wheel too!.........hopefully
Got plenty of time to find a suitabell chappie!
Phil Winks 107/07/2009 13:41:57
681 forum posts
269 photos
At 24' full size the model comes out at 1m with the slo mo wuold you not only need a bust and would racing/period civvy pilot style attire not look appropriate in which case have a nose around some of the model aircraft web shops esp "steve webb models" I think thats the name for a motor I'm utilising another model car 540 motor not so hot this time and geared right down for that 70mm scale prop hopefully giving a nice scale speed this is not one I want stood on its tail at full ahead. with any luck the drivers hand will appear to move the steering wheel in time with the rudder. The wheel should mount directly onto a micro servo below the control panel
Phil
Phil Winks 114/07/2009 16:26:02
681 forum posts
269 photos
At last I've got round to taking some photo's of the progress so far. not bad really thankfully no serious errors on the plan the formers have all gone together nicely.
The keel is solid Oak, the formers are 12mm wbp fair faced ply and the deck bearers are Obiechi. It will be planked with 2mm Mahogany planks laid length ways and sealed on the inside with resin. the round holes in formers 9, 8 & 7 are for cables and cooling tubes to run as most of the hardware will be housed under the central control console/seat
MyHobbyStore.co.uk Competitions
STO
M-Troniks
MountFleet
Premier Ship Models
BOCA BEARING
Brown, Sone and Ferguson
MyHobbyStore
Product Of The Month
MyHobbyStore
RRP £99.99
Now Only £90.95
Buy Now
